lfcfan Posted June 25, 2007 Share Posted June 25, 2007 im making a bebo skin and im rather stuck i have paint bucketed the background red then losded an image on it then i pressed the "A" button aand started typing and nothing shows up the color is different from the bkground can anyone help? oh yeah the image has white dots around it if tht helps? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 25, 2007 Share Posted June 25, 2007 Before you click the A button (for the text tool), press ESC. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
lfcfan Posted June 25, 2007 Author Share Posted June 25, 2007 thanks also if i wanted to use the same skin layout and wanted to resize it eg instead of 760x375 to 32x3,11x15,760x40 etc when i do resize itfor eg 32x3 it changes it to 6x3??? Quote Link to comment Share on other sites More sharing options...
chloett Posted June 25, 2007 Share Posted June 25, 2007 since this is a help text topic I hope I posting in the right place but I was wonder can I copy a text from a document or somewhere and paste it into the place that I want to add my text. i try doing it but it didn't work is it possible for me to copy and paste test or do I have to type in the text myself. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted June 25, 2007 Share Posted June 25, 2007 I have on many occasions done just that. As PDN doesn't have a spell checker yet Word does, I type it first in Word then copy and paste, I do not understand why it is not working for you. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
chloett Posted June 25, 2007 Share Posted June 25, 2007 hwo do you do it. I try right click but the menu doesn't pop up and I also try to drag and drop the text and it also didn't work. Am I doing it wrong? Quote Link to comment Share on other sites More sharing options...
Myrddin Posted June 25, 2007 Share Posted June 25, 2007 Copy your desired text from where ever, then in PDN either press Ctrl + V or go to Edit > Paste. That should do it. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
chloett Posted June 25, 2007 Share Posted June 25, 2007 thank you ver much it work, Quote Link to comment Share on other sites More sharing options...
Myrddin Posted June 25, 2007 Share Posted June 25, 2007 Good good. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
