Neil 0 Posted October 15, 2005 Report Share Posted October 15, 2005 Whenever I use the text tool in 2.5 Beta 3 it seems to type without antialising (not sure how to spell it) but clearly the button is selected. Is it just me? How can I fix it? This hapens with any font and just started with beta 3. Just found out: This only happens when using a font 12 points or smaller. Anything above that looks great. But still is a problem. Quote Link to post Share on other sites
Rick Brewster 1,757 Posted October 15, 2005 Report Share Posted October 15, 2005 This was actually by design, but it seems that there's really no benefit to doing it this way so I've changed it for the Beta 4 release. The reason it was designed this way is that often people want to take a screenshot of a dialog box and then type new text on top of it in order to prototype a new UI design. Having the Text Tool in Paint.NET render text in the same way as Windows was seen as a benefit. In fact, I had to add a special flag in order to disable this behavior. But anyway, there's really no benefit to using this behavior because you can just turn off AA when you need it to look that way! Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Neil 0 Posted October 15, 2005 Author Report Share Posted October 15, 2005 OK, so there will be a fix for this in beta 4? Any expected release date for beta 4? Quote Link to post Share on other sites
Rick Brewster 1,757 Posted October 15, 2005 Report Share Posted October 15, 2005 Yes, it's fixed for beta 4. I just checked in the code. We're shooting for a Monday release. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Neil 0 Posted October 15, 2005 Author Report Share Posted October 15, 2005 Great! Thanks! I love Paint.net Quote Link to post Share on other sites
