Kesaslov Posted February 7, 2007 Share Posted February 7, 2007 I am creating a logo for work for a letter head. I was using 300 pixels per sq inch and size page of 2.77 x 1.05 Can anyone tell me why when I save the image and bring it in to a Word document, the image is very Grainy? I have tried to save it as a .bmp, .jpeg, and .gif. Thanks for any help that I get Quote Link to comment Share on other sites More sharing options...
Kesaslov Posted February 7, 2007 Author Share Posted February 7, 2007 I created it paint.net then when I bring it into WORD its still grainy. What is the best format to save the design under jpeg, bmp? I'm looking for best quality. Quote Link to comment Share on other sites More sharing options...
Kesaslov Posted February 7, 2007 Author Share Posted February 7, 2007 email me at kesaslov@aol.com and I will forward you the different formats if that is ok. I couldnt find out how to upload my logo. Thanks [/url] Quote Link to comment Share on other sites More sharing options...
Kesaslov Posted February 7, 2007 Author Share Posted February 7, 2007 no that's fine, you can leave it up there... I did play with the sharpness on it (Sunglasses icon) and changed it a few times. It did make it better. Yea your right, blurriness and grainy, meant to be the same. I never saved it as a pdn I did initially make the column only in windows paint. But it doesnt matter, the blurryness is the same with the column and the "mperial capital lending" part. Any other suggestions? thanks again. Quote Link to comment Share on other sites More sharing options...
Kesaslov Posted February 7, 2007 Author Share Posted February 7, 2007 I'll try that again, thanks Quote Link to comment Share on other sites More sharing options...
Kesaslov Posted February 8, 2007 Author Share Posted February 8, 2007 I do like the logo with the words in the middle, I will now incorperate that into the design. I still however keep coming up with the column being just a little blurry. I redid the entire design but now its more clearer but still blurry, I guess Paint.net isnt for something like this. Quote Link to comment Share on other sites More sharing options...
Kesaslov Posted February 8, 2007 Author Share Posted February 8, 2007 right, I know about the stretching. I'm setting it up as the page size first than designing in that page size rather than stretching it. Thanks again, I do like your middle disign better Quote Link to comment Share on other sites More sharing options...
MadJik Posted February 8, 2007 Share Posted February 8, 2007 I would suggest some shadow instead the blur on the column... It should avoid the grany effect. Also try in .png format... Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to comment Share on other sites More sharing options...
Kesaslov Posted February 14, 2007 Author Share Posted February 14, 2007 Thanks man, appreciate the info. Quote Link to comment Share on other sites More sharing options...
