juanz-dezignz Posted January 7, 2007 Share Posted January 7, 2007 It wont start, all I get is a message. Can anyone help? Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
Illnab1024 Posted January 7, 2007 Share Posted January 7, 2007 You need to reinstall PdN. A dll got deleted somewhere... Quote ~~ Link to comment Share on other sites More sharing options...
juanz-dezignz Posted January 7, 2007 Author Share Posted January 7, 2007 but i tried that allready..but for some reason i get another message on add/delete programs.. Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
Illnab1024 Posted January 7, 2007 Share Posted January 7, 2007 A couple of things to say: You should have posted this in Bugs and Troubleshooting, if there weren't a topic covering it already: http://paintdotnet.12.forumer.com/viewtopic.php?t=854 Look at this, and you should see number two in Rick's post. Quote ~~ Link to comment Share on other sites More sharing options...
juanz-dezignz Posted January 7, 2007 Author Share Posted January 7, 2007 thanks :oops: :oops: Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 7, 2007 Share Posted January 7, 2007 Please make sure to post in the correct forum. Moved to Bugs & Troubleshooting Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
juanz-dezignz Posted January 7, 2007 Author Share Posted January 7, 2007 yes, i noiced..but while i was going to download the program u recomended, but this is what i got and i was wondering if it was an virus-free program.. Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 7, 2007 Share Posted January 7, 2007 I have no idea what StartMsi.vbs is. It's probably just a benign VB Script for running an MSI file (MSI = Windows Installer file). Norton likes to classify all scripts as malicious in their user interface, like what you see in your screenshot. Even though they can only potentially be malicious. But like I said, I don't know anything about that StartMsi.vbs file or where it's from or anything. Nor do I know what you clicked on that caused that prompt to come up. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
juanz-dezignz Posted January 7, 2007 Author Share Posted January 7, 2007 i use firefox just incase u didnt see that.. and i just clicked open on the download screen.. Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 7, 2007 Share Posted January 7, 2007 Um, which download screen? I have no idea which download screen you are referring to. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Illnab1024 Posted January 7, 2007 Share Posted January 7, 2007 It's a list of downloads in chronological order, in firefox (Ctrl+J) - using Run on a download will use the Windows default application to run it, so an executable would naturally open and initialize. Quote ~~ Link to comment Share on other sites More sharing options...
juanz-dezignz Posted January 7, 2007 Author Share Posted January 7, 2007 This one Rick. Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 7, 2007 Share Posted January 7, 2007 Ok well you're trying to use the MSI Cleanup Utility described in that other post. I can only point you to the utility and what to do with it. I can't help you troubleshoot the utility itself or your antivirus software. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
juanz-dezignz Posted January 7, 2007 Author Share Posted January 7, 2007 ok thanks. ohh..and sorry for trying to advertise.:oops: Quote --CREDIT TO RAVEN-- Link to comment Share on other sites More sharing options...
