debborella58 Posted November 24, 2012 Share Posted November 24, 2012 I have been using Paint.NET for a long time, and a few days ago I noticed a slow response when I was using the features (i.e. Affects, Adjustments, Layer Properties). Before, whenever I was making a graphic, the changes I was making would show right at the time of each and every adjustment. Now I notice that it takes several seconds to show any changes I make (i.e. if using GLOW, when adjusting radius, brightness, contrast, all adjustments lag.) Then if I get the desired look I want, it will take several seconds to render. I have not added any plug-ins or changed any settings...the only update that has been done on my laptop is an Adobe update. I am using Windows Vista, by the way. Could you give me a solution as to how to remedy this problem? Thank you for your time. Debbie Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 24, 2012 Share Posted November 24, 2012 My guess is that you are working on a large image. Large images take more time to render on (because there are more pixels to change) Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
kreemoweet Posted November 24, 2012 Share Posted November 24, 2012 It doesn't seem like the operation of PDN would just change all by itself. You should investigate what's going on with the rest of your computer. For instance, some program or Windows service doing some heavy work in the background, or perhaps a hardware glitch creating an "interrupt storm" could be causing the symptoms you describe. The Windows Task Manager will give you lots of information about that kind of stuff. Quote Link to comment Share on other sites More sharing options...
debborella58 Posted November 24, 2012 Author Share Posted November 24, 2012 My guess is that you are working on a large image. Large images take more time to render on (because there are more pixels to change) Thank you for the reply. But I am using the same type/size of images that I have always worked with. Even if I am trying to just "recolor" or "glow" a small 256 x 256 png icon, it still lags. Like I said, all was well a few days ago, so it's got me baffled. Quote Link to comment Share on other sites More sharing options...
debborella58 Posted November 24, 2012 Author Share Posted November 24, 2012 It doesn't seem like the operation of PDN would just change all by itself. You should investigate what's going on with the rest of your computer. For instance, some program or Windows service doing some heavy work in the background, or perhaps a hardware glitch creating an "interrupt storm" could be causing the symptoms you describe. The Windows Task Manager will give you lots of information about that kind of stuff. Thank you. I will check into that. I don't know that anything has changed on my computer other than that Adobe update, but I will do the Task Manager thing. Thanks for that advice. Quote Link to comment Share on other sites More sharing options...
debborella58 Posted November 27, 2012 Author Share Posted November 27, 2012 A miracle (?) has occurred! It seems to be working fine once again. Don't know how or why, but VERY happy it did. Thanks to those who offered suggestions. Debbie Quote Link to comment Share on other sites More sharing options...
