Hatman123466 Posted October 27, 2012 Share Posted October 27, 2012 Hi, I am a windows 7 X64 user and I am having a problem with both object outline/ trail plugins, as they have no effect. I have install them twice on a vista and a Xp computer and they worked 100% fine. But now when i try and use them on my windows 7 computer they don't work. All the other plugins in the pack work, and I have tried 2 different plugins, neither of which worked. I have tried everything that I can think of, has anyone had this problem before, if so then i would like to know the solution to it. thanks PS: If this is in the wrong section can you polity tell me that it is. Quote Link to comment Share on other sites More sharing options...
minners71 Posted October 27, 2012 Share Posted October 27, 2012 The objects need to be on their own layer and on a transparent background for both of those plug-ins to work. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 28, 2012 Share Posted October 28, 2012 Yeah this isn't a plugin development question. Moved to general section. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
