pipsgeorge Posted May 21, 2012 Share Posted May 21, 2012 I have a JPG which is a black and white line drawing I want to drop this on a collage where the line drawing shows, but the background must be transparent so other things come through. Essentially, I want to turn the color [ or lack thereof] white to be transparent, and black to be black. I haven't got the foggiest idea how to do this, or if it can be done. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 21, 2012 Share Posted May 21, 2012 JPG does not support transparency. You will need to use PNG. Also, this is not a tutorial. You shouldn't post questions in a section clearly marked as "Tutorials Publishing ONLY". I'll move this to General Discussion & Questions for you. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
pipsgeorge Posted May 21, 2012 Author Share Posted May 21, 2012 MY apology, I posted this without making sure I was in the right forum. Sorry! Quote Link to comment Share on other sites More sharing options...
jim100361 Posted May 21, 2012 Share Posted May 21, 2012 (edited) Since your intent is to put it into a collage, you can use the .jpg. I think Rick mistunderstood. If you used a jpg, erased the white so it became transparent, and then tried to save it again as a jpg, the transparent part would turn white again. In this case however, you can get what you want. Open your background image Import your b/w image as another layer (Menus: Layers > Import from File) Click on the magic wand on the tools pane Next click on the white area (use the control key if selecting different white areas) Once all he white has been selected simply press the Delete key on your keyboard If all is well, on the layers pane, click on the button to merge the image down (or simply save it and PDN will ask if you want to flatten it - respond "Yes' Edited May 21, 2012 by jim100361 Quote Link to comment Share on other sites More sharing options...
