Bob Hawkins Posted April 27, 2012 Share Posted April 27, 2012 Paint.NET informs me that my photographic images are 2592 x 1944 pixels with a 72 pixels/inch (28.35 pixels/cm) resolution measuring 36 x 27 inches (91.44 x 68.58 cm). Why is it that printed copies at 15 x 10 centimetres using the File>Print facility directly in Paint.NET are far superior to those using Image>Resize before printing (without saving the resized image)? Is there any means by which I can intervene to resize the image myself without losing the original quality? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted April 27, 2012 Share Posted April 27, 2012 I don't understand. If the print quality is great without using Image->Resize, why would you even bother to invoke Image->Resize? If you need to change the "print size" of the image, you can do that just by fiddling with the Resolution property (in Image->Resize). "Print Size" is purely a function (in the mathematical sense) of Resolution and Pixel Size. You don't need to resize the image to a new pixel size in order to affect the print size. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Bob Hawkins Posted April 28, 2012 Author Share Posted April 28, 2012 Rick, I was simply trying to understand the process. I guess I used to use Resize, thinking that was what I had to do to print on to 15 x 10 cms photo paper, before I discovered that using File>Print did it automatically. If, by using Resize, the Resolution remains the same and I cannot alter that without the size being altered, I guess that means a coarser result on a small sheet of photo paper. But why does using the File>Print facility not result in the same coarser image? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted April 28, 2012 Share Posted April 28, 2012 Probably because the Print facility in Paint.NET is honestly not very good. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
