"side-by-side configuration is incorrect"
Paint.net is not working for me when I try to launch it: "The application has failed because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail."
So, when I attempt to do an uninstall from the control panel to uninstall and then try a new install, this pops up: "There us a problem with this Windows Installer package. A program required for this install to complete could not be run."
I've gone through the installer posts already to make sure I have net framework, etc in place.
Thanks so much, tammi
Try running the file PdnRepair.exe. It'll be wherever you installed Paint.NET, eg C:\Program Files\Paint.NET\PdnRepair.exe
Thank you - should have mentioned I tried that, too. the same error comes up:
What version of Paint.NET do you have installed?
Which version of the .NET framework do you have? Do you have .NET 3.5 SP1?
Have you tried repairing the framework?
Paint.net: 3.5.8
.NET framework 3.5.1; repaired the framework, restarted. Same thing.
