COMTIBoy Posted February 26, 2011 Share Posted February 26, 2011 Hi Everyone, I have a problem I was hoping someone could give me guidance on . If I select Layers\Import from File... to import a new image into my current project, then anchor the cloning brush (in the newly imported), then select a location from the existing image...I can successfully clone. I'm trying to figure out how soften or reduce the opacity of just the brush. In other words, what I'm cloning comes out way to strong. In some other packages, I'm able to set the opacity of the brush to soften what I'm copying. Anyway to easily do this with Paint.NET ? Quote Link to comment Share on other sites More sharing options...
mountnman Posted February 26, 2011 Share Posted February 26, 2011 i dont do much cloning work,(never actualy used it) but could you clone to a seperate layer then set the opacity of that layer down? Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
Sarkut Posted February 26, 2011 Share Posted February 26, 2011 In the Colors window, click More >> . Adjust the Alpha - Transparency slider of the primary color. Quote Link to comment Share on other sites More sharing options...
COMTIBoy Posted February 28, 2011 Author Share Posted February 28, 2011 In the Colors window, click More >> . Adjust the Alpha - Transparency slider of the primary color. This worked perfectly. Thanks! Quote Link to comment Share on other sites More sharing options...
