mbecker2800 Posted February 26, 2011 Share Posted February 26, 2011 Hi pretty new here. When I draw a line and then draw something else how do I go back to edit the first line. Along these same lines how would I mirror a line so that both halves are identical. Thanks Mike Quote Link to comment Share on other sites More sharing options...
mountnman Posted February 26, 2011 Share Posted February 26, 2011 on the first question- if you draw a line with the line/curve tool, once you move on to something else, you cannot go back and resume using those controls- you could, however, useone of the selection tools to select the line(magic wand should work) then use the move selected pixels tool to adjust its basic demensions and/or position. any of the distort tools can also be used to modify the image (lens, sin waves, twist, etc.) on the second - if you made the line on a seperate layer, then you could duplicate the layer and use the move selected pixels tool too reposition the second layer/line, you could also use the mirror plug-in - http://forums.getpaint.net/index.php?showtopic=6828 - or even select the first line and copy/paste http://forums.getpaint.net/index.php?/forum/36-how-to-install-pluginsgeneral-plugin-troubleshooting/ some tuts that might be helpful http://forums.getpaint.net/index.php?/topic/12194-levels-a-how-to-and-basic-understanding-now-a-pdf/ http://forums.getpaint.net/index.php?/topic/12156-resource-portal-for-new-users/ http://forums.getpaint.net/index.php?/topic/12185-interactive-beginners-guide-updated-jan-22-2008/ Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
