Rick Brewster Posted July 27, 2005 Share Posted July 27, 2005 You need the full Visual Studio package, as we make use of Visual C++ as well. Just Visual C# will not work. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 27, 2005 Author Share Posted July 27, 2005 Run the 'clean.bat' file in the src directory, and then try again. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
kenexcelon Posted September 5, 2005 Share Posted September 5, 2005 I didn't see this in the readme's but should be there. They should state you need to have tablet pc sdk installed. That fixed my problems. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 5, 2005 Author Share Posted September 5, 2005 There are two readme's. The first one points you to src/readme.txt. Paint.NET Source Code ReadmePrerequisites ------------- 1. The source must be located in a directory that does not have spaces in its full path name. So extracting and building from your desktop won't work. The reason for this requirement is related to a limitation with the help file compiler. So, for example: Works: c:\src\pdn_2_1_src\ Won't: c:\Documents and Settings\username\Desktop\pdn_2_1_src 2. Windows XP or Windows Server 2003, or newer. You might be fine with Windows 2000 but this hasn't been tested. 3. Visual Studio .NET 2003 Professional 4. .NET Framework 1.1 with SP1 Install .NET 1.1 using programs/dotnetfx.exe, and then apply SP1 with the appropriate executable from the programs/dotnet_1_1_sp1 directory. 5. Tablet PC SDK v1.7 Install this from the programs directory, or download from Microsoft: http://www.microsoft.com/downloads/deta ... layLang=en Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 2, 2005 Author Share Posted October 2, 2005 Sometimes when you get this, try... 1. Close all windows within Visual Studio 2. Close Visual Studio 3. Run the 'clean.bat' batch file in the src directory 4. Open Visual Studio, and the paintdotnet solution 5. Immediately do Build -> Rebuild Solution Never fails to work for me. Visual Studio gets confused and cranky sometimes. I find that always doing a Rebuild instead of just a Build helps keep it in check better. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
