A HUGE problem!
I didn't know where to put this so sorry id its in the wrong catagorie :oops:
I downloaded one of the 3.0 betas a while ago and am now wanting to go back to 7.5 (or whatever the newest official release is) fo a bit. I tried simply installing 7.5 but it said 'Unable to install because there is a newer version of PDN on your PC'.
So I tried to uninstall the PDN beta, but found that the file C:/Program Files/Paint.net only contained 1 couple of files (a file called 'Staging') and no uninstaller.
So I went into Add/Remove Programs, scrolled down to Paint.NET Beta and clicked Remove. It went through the uninstall process and nearly removed the program, but sudennly a box popped up saying 'FATAL ERROR: PDN WASN'T REMOVED!'
Does ANYONE have a solution???
Thanks
Zacariem 8)
They said we couldn't fly.
We did.
Anythings possible!
