Cohete Posted September 12, 2006 Share Posted September 12, 2006 Hello, I'm from Chile, and I used Paint.net. I dont know what happen. Today I open it, and y cant. But is not only that. I cant removed, or overinstaled. Step by Step: When I try to open It, showme that: When I try to deleted tell me that: And when I try to overinstaled or instaled, tell me that: Plis I pray for your help. I dont wrote very good, but I can understand yours explication. Plis, I use some much this program. And I dont Know hoe Fix it. Plis. Thx. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 12, 2006 Share Posted September 12, 2006 Moved to Bugs & Troubleshooting Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 12, 2006 Share Posted September 12, 2006 It's possible that your .NET Framework 2.0 installation needs to be repaired. In the Add/Remove Programs control panel, find "Microsoft .NET Framework 2.0" and click on it. Then click on the "Change/Remove" button. Then, it should give you the option of repairing. Do this, and try running Paint.NET again. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
trickman Posted September 12, 2006 Share Posted September 12, 2006 Ès possivel que tu .NET Framework 2.0 instalacion necessita de ser reparada. En Adicionar/Remover Programas, encontra "Microsoft .NET Framework 2.0" y clica-lo. A seguir, clica en "Modificar/Remover". Depués, aparecerá lá opción de reparar. Hace-lo y tenta abrir Paint.NET de nuevo. (I'm portuguese, not spanish, BTW...) Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted September 12, 2006 Share Posted September 12, 2006 Yeah I notice....a little crazy on the accents there... Understandable, though. Quote ~~ Link to comment Share on other sites More sharing options...
Cohete Posted September 12, 2006 Author Share Posted September 12, 2006 Thx, I will do that when I back to my home, cause now I'm in the University. I hope it works. ^^ Quote Link to comment Share on other sites More sharing options...
Cohete Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks man!! It Work ir, now I can open my Paint.net. A lot of Thanks. U Rox! Quote Link to comment Share on other sites More sharing options...
