Dani Posted January 11, 2010 Share Posted January 11, 2010 So, there's a problem with my fonts AND trying to add plugins. Here's the gist of it: I Save the font onto my desktop. Extract, etc. all that good stuff. I go to the Fonts section of my Local Disk and (try) drag and drop it into the Font section, and I get this: http://i50.tinypic.com/27zmfc7.jpg I need to know how to fix this. And now with the adding plugins into PdN. So, I download the plugin, save it, etc. etc. So, I go to Windows and all that, click the PdN link, and go to 'Effects' to put in the plugin, and I get this: http://i48.tinypic.com/8y8ac4.jpg I really need to fix this. Any ways? Quote Happy Samhein. Link to comment Share on other sites More sharing options...
Sarkut Posted January 11, 2010 Share Posted January 11, 2010 Dani, Re: SinWaves, first be sure that your hard drive isn't out of free space and is not write protected. Best to have Paint.NET closed when installing the plugin file. Are you doing this from an account with administrator's privilege? Quote Link to comment Share on other sites More sharing options...
Scorpio Posted January 11, 2010 Share Posted January 11, 2010 With your font one, close everything that uses fonts, ms paint, paint.net, ps, etc.. and then put it in there. But your picture says replacing it, which means you already have the font. Quote [center]yoyoyo [img]http://i45.tinypic.com/20p3nyh.png[/img][/center] Link to comment Share on other sites More sharing options...
Sarkut Posted January 11, 2010 Share Posted January 11, 2010 Good point. That font indexes under "J" for Jellyka, not "G" for Gare. Quote Link to comment Share on other sites More sharing options...
Dani Posted January 13, 2010 Author Share Posted January 13, 2010 Sarkut, No, I have a Limited Account, is that what's causing this? Scorpio & Sarkut, I checked PdN and it's uner 'N' for 'Nowhere.' ;-( Quote Happy Samhein. Link to comment Share on other sites More sharing options...
Sarkut Posted January 13, 2010 Share Posted January 13, 2010 Sarkut,No, I have a Limited Account, is that what's causing this? Maybe. Best way to find out is to have someone with admin acct. try it for you. Quote Link to comment Share on other sites More sharing options...
