BlissC Posted November 29, 2009 Share Posted November 29, 2009 At the moment I'm working on a site I need to illustrate with different types of human cells. I'm struggling to find anything suitable to fit in with the design of the site on the stock photography site, so decided to try and create some of my own, but they're very amateurish and one-dimensional. I did find a Photoshop tutorial on the web for creating red blood cells (sometimes I've found that I can adapt Photoshop tutorials and "translate" them into PDN), but couldn't replicate the same effect with PDN using it on this occasion. I've had a search around the forums and waded through tutorials in the hope of finding some sort of effect that either looks like cells, or that could be adapted to create cells, but haven't found anything suitable. Obviously there are various shapes and sizes and textures of cells (textures aren't too much of a problem because with the various texture effects in PDN it's pretty easy to create all kinds of textures) but I'm struggling to figure out how to do flatish but 3D cells, and for example red blood cells which are 3D "disks" with a concave "dips" in their centre. Any suggestions or hints for how I can do some fairly realistic (or at least not that look they've been drawn by a 5-year-old using Paint) cells? Quote Link to comment Share on other sites More sharing options...
Curmudgeon Posted November 29, 2009 Share Posted November 29, 2009 here's one I did while messing around with BoltBait's bevel plugin a while back: I started out by filling a larger circle with a less saturated red to a vibrant red radial gradient on one layer, then a smaller circle on another layer with the primary/secondary colors flipped and radial gradient again. Then, I magic wand selected the larger circle and ran bevel using a large radius with a couple different red colors as the shadow and highlight colors. Then did the same thing on the smaller circle, except switched the lighting direction. Then, I merged the 2 circle layers down and magic wand selected the one circle, and used an average blur on it to make the transition less pronounced. Quote Link to comment Share on other sites More sharing options...
BlissC Posted November 29, 2009 Author Share Posted November 29, 2009 Thanks - that's the sort of effect I'm aiming for. It never occurred to me to try BoltBait's bevel plugin. I tried Shape3D but the shapes were too round (though thinking about it, I guess with a bit of distortion they could be cell-like. I'll have a go with your method though and see what I come up with. Thanks! Quote Link to comment Share on other sites More sharing options...
BlissC Posted November 29, 2009 Author Share Posted November 29, 2009 Well this is my first attempt (I've used it with a background from cjmcguinness's "How to make insides" tutorial, which seemed quite fitting). Still needs a lot of work, but I've got the general idea of it. Quote Link to comment Share on other sites More sharing options...
Sarkut Posted November 29, 2009 Share Posted November 29, 2009 BlissC: If you do a Vertical and Horizontal flip of the inner highlights/shadows relative to the outer highlights/shadows it will give a sense of a concave center portion as is typical in red blood cells. The center appears to stick out as they are now. Quote Link to comment Share on other sites More sharing options...
BlissC Posted November 29, 2009 Author Share Posted November 29, 2009 Ah, yep, I see what you mean. I'll have another play with it tomorrow after work. Thanks. Quote Link to comment Share on other sites More sharing options...
