mmatty Posted September 3, 2009 Share Posted September 3, 2009 Hi, I was woundering if i could make a light around a frame like in this picture http://www.fpsbanana.com/sprays/50268 (u have to download the picture to see what i mean, im not so good to explain on english...) Mmatty Quote Link to comment Share on other sites More sharing options...
KidBoy140 Posted September 3, 2009 Share Posted September 3, 2009 I hope this is what you mean: 1. Use the Rounded Rectangle Tool to draw the Rounded Rectangle (obviously) 2. Use Boltbait's Bevel Plugin 3. Use Outline Object 4. Then use Drop Shadow with a fairly high Blur Radius. Hope this solves your problem, this is quite brief but I hope this helps. Quote Link to comment Share on other sites More sharing options...
MiguelPereira Posted September 3, 2009 Share Posted September 3, 2009 You mean the screenshot or the Naruto image? Quote [The stock on my sig is a photo I took not a render from Splatter] [My deviantART][My Gallery][My Space] Link to comment Share on other sites More sharing options...
mmatty Posted September 4, 2009 Author Share Posted September 4, 2009 KidBoy140, Yeah that was exacly what i mean^^ But where can i download Drop Shadow? I tried Vandermotten plugin pack with drop shadow but i cant get it work... Quote Link to comment Share on other sites More sharing options...
nemo Posted September 4, 2009 Share Posted September 4, 2009 Here :wink: Quote Link to comment Share on other sites More sharing options...
mmatty Posted September 4, 2009 Author Share Posted September 4, 2009 Thank you all^^ now i only have one question back... In the frame on that picture i linked at the start there is a lot of lines in the frame with 2 dot space... How can i make that? i can only find how to make 3 dot space.... Hope u understand that:P Quote Link to comment Share on other sites More sharing options...
KidBoy140 Posted September 4, 2009 Share Posted September 4, 2009 I think that's just because it's a low quality picture. Quote Link to comment Share on other sites More sharing options...
