skygod Posted May 6, 2009 Share Posted May 6, 2009 I have a problem, Becouse i was created Poster A3, and my work is very slow. P.S. I have a strong computer with 2 cores. And More Ram. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 6, 2009 Share Posted May 6, 2009 Moved to Troubleshooting Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
ken_dot_pistol Posted May 7, 2009 Share Posted May 7, 2009 I have an older single core Dell. When I add more brushes etc.. I had several crashes and massive slow CPU response. I eventually had to bump up the Virtual Memory to max. You may want check if the Graphics card could be updated. I dont have anymore suggestions. Good Luck Quote Link to comment Share on other sites More sharing options...
skygod Posted May 7, 2009 Author Share Posted May 7, 2009 Today when I wanted to save to png format (this poster A3), i have a problem Ps. I have a current drivers to my graphic card. I update my computer very often. I have a GeForce 9600 DDR 3, 512MB, and 3GB RAM Memory. CPU is 2,8Ghz (Dual cores) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 8, 2009 Share Posted May 8, 2009 Please post the crash log that it is referring to. This won't have anything to do with the memory on your graphics card. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Lance McKnight Posted May 8, 2009 Share Posted May 8, 2009 Just out of curiousity...have you tried to run defrag? I find that it helps to speed up the graphic program periodically. *makes mental note to actually run the defrag* Quote Officially retired from this forum. Have a nice day. Link to comment Share on other sites More sharing options...
skygod Posted May 8, 2009 Author Share Posted May 8, 2009 I made recently defrag, and nothing: Report: This text file was created because Paint.NET crashed. Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem. Application version: Paint.NET v3.36 (Final Release build 3.36.3158.38068) Time of crash: 2009-05-06 11:55:49 Application uptime: 00:39:48.9218750 OS Version: 5.1.2600.196608 Dodatek Service Pack 3 Workstation x86 .NET version: CLR 2.0.50727.3082 x86, FX 2.0 2.0SP1 2.0SP2 3.0 3.0SP1 3.0SP2 3.5 3.5SP1 3.5SP1_Client Processor: 2x "AMD Athlon 64 X2 Dual Core Processor 5400+" @ ~2799MHz (DEP, SSE, SSE2) Physical memory: 3071 MB UI DPI: 96,00 dpi (1,00x scale) Tablet PC: no Updates: false, err Locale: pdnr.c: pl-PL, hklm: pl-PL, hkcu: n/a, cc: pl-PL, cuic: pl-PL Features log: PopulateFonts(), UpdatesState(StartupState), SetTool(PaintDotNet.Tools.PaintBrushTool), UpdatesState(ReadyToCheckState), HM(NullHistoryMemento), ShowDialog(PaintDotNet.ToolsForm), ShowDialog(PaintDotNet.ColorsForm), ShowDialog(PaintDotNet.HistoryForm), ShowDialog(PaintDotNet.LayerForm), ShowDialog(PaintDotNet.MainForm), Menu.File, Open, AWAction(OpenFileAction), Load(PaintDotNet.PdnFileType), HF(AddNewBlankLayerFunction), HM(NewLayerHistoryMemento), HM(BitmapHistoryMemento), HF(DuplicateLayerFunction), HF(DeleteLayerFunction), HM(DeleteLayerHistoryMemento), SetTool(PaintDotNet.Tools.TextTool), Paste, PasteAction, HM(CompoundHistoryMemento), SelectAll, HF(SelectAllFunction), HM(SelectionHistoryMemento), Undo, DWAction(HistoryUndoAction), Menu.Layers, RotateZoom, ShowDialog(PaintDotNet.Effects.RotateZoomEffectConfigDialog), ShowDialog(PaintDotNet.ProgressDialog), SetTool(PaintDotNet.Tools.MoveTool), HM(ContextHistoryMemento), HM(CompoundToolHistoryMemento), EraseSelection, HF(EraseSelectionFunction), SetTool(PaintDotNet.Tools.MagicWandTool), Menu.Effects, Effect(PaintDotNet.Effects.GaussianBlurEffect), ShowDialog(PaintDotNet.Effects.PropertyBasedEffectConfigDialog), Deselect, HF(DeselectFunction), Effect(Vandermotten.PaintDotNetEffects.Blurs.AverageBlurEffect), CommonActionsStrip(Save), Save(PaintDotNet.PngFileType), Save(PaintDotNet.PdnFileType), ToolConfigStrip(fontAlignCenterButton), ToolConfigStrip(fontAlignRightButton), Save, ToolConfigStrip(fontAlignLeftButton), Menu.Layers.Adjustments, Effect(Vandermotten.PaintDotNetEffects.Samples.LightenAdjustment), HF(MergeLayerDownFunction), RepeatEffect(PaintDotNet.Effects.GaussianBlurEffect), SaveAs, ShowDialog(PaintDotNet.SaveConfigDialog), ShowDialog(PaintDotNet.TaskDialog+TaskDialogForm), HF(FlattenFunction), HM(ReplaceDocumentHistoryMemento) Loaded assemblies: mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll PaintDotNet, Version=3.36.3158.38068, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.exe System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll PaintDotNet.Core, Version=3.36.3158.38063, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.Core.dll PaintDotNet.Base, Version=3.36.3158.38062, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.Base.dll PaintDotNet.SystemLayer, Version=3.36.3158.38062, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.SystemLayer.dll PaintDotNet.Resources, Version=3.36.3158.38063, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.Resources.dll PaintDotNet.Data, Version=3.36.3158.38064, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.Data.dll System.Windows.Forms.resources, Version=2.0.0.0, Culture=pl, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms.resources\2.0.0.0_pl_b77a5c561934e089\System.Windows.Forms.resources.dll PaintDotNet.Effects, Version=3.36.3158.38065, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\PaintDotNet.Effects.dll AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\AdvGrey.dll AlphaMask, Version=1.1.2465.20599, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\AlphaMask.dll CodeLab, Version=3.0.2632.38238, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\CodeLab.dll ColorBalance, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\ColorBalance.dll CondHSAdj, Version=1.7.2618.31817, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\CondHSAdj.dll CutoutEffect.cs, Version=1.0.2404.21446, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\CutoutEffect.dll EasyWatermark1, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\EasyWatermark1.dll Feather, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Feather.dll Flip, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Flip.dll FlipPlugin, Version=1.0.2475.32074, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\FlipPlugin.dll GaussianBlurPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\GaussianBlurPlus.dll Gradient, Version=2.0.2477.21844, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Gradient.dll GridMaker, Version=2.0.2490.35869, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\GridMaker.dll HexaGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\HexaGrid.dll InkSketch, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\InkSketch.dll Kaleidoscope, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Kaleidoscope.dll Majority, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Majority.dll MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\MultiColorGradient.dll Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Oblique.dll Octagonal, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Octagonal.dll Outline, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Outline.dll Panelling, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Panelling.dll Pastel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Pastel.dll PolarRect, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\PolarRect.dll Polygon, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Polygon.dll PortraitEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\PortraitEffect.dll ReflectionFlat, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\ReflectionFlat.dll RGB2CMYK, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\RGB2CMYK.dll SeamlessHelper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\SeamlessHelper.dll Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Shape3D.dll SpiroShapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\SpiroShapes.dll Steganography, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Steganography.dll StripPrimaryColor, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\StripPrimaryColor.dll Transparency, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Transparency.dll Tube Oblique, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Tube Oblique.dll Vandermotten.PaintDotNetEffects.Blurs, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll Vandermotten.PaintDotNetEffects, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.dll Vandermotten.PaintDotNetEffects.DropShadow, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll Vandermotten.PaintDotNetEffects.Duotones, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll Vandermotten.PaintDotNetEffects.Monochromes, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll Vandermotten.PaintDotNetEffects.Samples, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vandermotten.PaintDotNetEffects.Samples.dll Vibrato, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Vibrato.dll Water, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Water.dll Waves, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\Effects\Waves.dll DdsFileType, Version=1.11.3158.38065, Culture=neutral, PublicKeyToken=null @ E:\Partition_0_3\Programy\paintnet3.36\FileTypes\DdsFileType.dll mscorlib.resources, Version=2.0.0.0, Culture=pl, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll Exception details: System.OutOfMemoryException: CreateDIBSection returned NULL (0) while attempting to allocate 3508x4960 bitmap w PaintDotNet.SystemLayer.Memory.AllocateBitmap(Int32 width, Int32 height, IntPtr& handle) w PaintDotNet.MemoryBlock.Allocate(Int32 width, Int32 height, IntPtr& handle, Boolean allowRetry) w PaintDotNet.MemoryBlock.Allocate(Int32 width, Int32 height, IntPtr& handle, Boolean allowRetry) w PaintDotNet.MemoryBlock..ctor(Int32 width, Int32 height) w PaintDotNet.Surface..ctor(Int32 width, Int32 height) w PaintDotNet.Surface..ctor(Size size) w PaintDotNet.DocumentWorkspace.OnDocumentChanged() w PaintDotNet.DocumentView.DocumentSetImpl(Document value) w PaintDotNet.DocumentView.set_Document(Document value) w PaintDotNet.DocumentWorkspace.PaintDotNet.IHistoryWorkspace.set_Document(Document ) w PaintDotNet.HistoryFunctions.FlattenFunction.OnExecute(IHistoryWorkspace historyWorkspace) w PaintDotNet.HistoryFunction.Execute(IHistoryWorkspace historyWorkspace) w PaintDotNet.DocumentWorkspace.ExecuteFunction(HistoryFunction function) w PaintDotNet.DocumentWorkspace.DoSave(Boolean tryToFlatten) w PaintDotNet.DocumentWorkspace.DoSaveAs() w PaintDotNet.Menus.FileMenu.MenuFileSaveAs_Click(Object sender, EventArgs e) w System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) w System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) w PaintDotNet.PdnMenuItem.OnClick(EventArgs e) w System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) w System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) w System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) w System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) w System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) w System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) w System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) w System.Windows.Forms.Control.WndProc(Message& m) w System.Windows.Forms.ScrollableControl.WndProc(Message& m) w System.Windows.Forms.ToolStrip.WndProc(Message& m) w System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) w System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) w System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) w System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ------------------------------------------------------------------------------ Quote Link to comment Share on other sites More sharing options...
Lance McKnight Posted May 8, 2009 Share Posted May 8, 2009 Are all of your Plugin current? Sometime I found that if the older version of the Plugin was installed, it could cause a crash. Quote Officially retired from this forum. Have a nice day. Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 8, 2009 Share Posted May 8, 2009 Why did you attach it as a JPEG? I can't even read it :? Just copy the text into a block ... Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
skygod Posted May 12, 2009 Author Share Posted May 12, 2009 ok, i now put txt information on the top. Quote Link to comment Share on other sites More sharing options...
