Ruhana Posted March 19, 2009 Share Posted March 19, 2009 I'm trying to work on some textures for Unreal, but the transparency values in Paint.NET TGA's show up as white when importing into UnrealEd. Is there a plugin to save alpha info into a separate channel in the TGA? Using Photoshop works fine, but I'd like to work with Paint.NET if I can. Thanks! Quote T shirts printing Link to comment Share on other sites More sharing options...
Urnemanden Posted March 19, 2009 Share Posted March 19, 2009 I dont know, but you could try save as png and then convert to TGA. Quote About - Website Link to comment Share on other sites More sharing options...
Rick Brewster Posted March 19, 2009 Share Posted March 19, 2009 Paint.NET is saving TGA files according to the official TGA specification. Make sure you save as 32-bit, and not 24-bit. The latter does not have an alpha channel at all, so the image is first blended on top of a white background. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
