OhZone Posted March 3, 2009 Share Posted March 3, 2009 Lets say I have a picture of Uncle Fred. I want to make his nose bigger. What do you think the best technique for this is? Many thanks. Quote Link to comment Share on other sites More sharing options...
HELEN Posted March 3, 2009 Share Posted March 3, 2009 You can try this and select the nose and enlarge it. Just follow the steps and you'll get a very good effect. Quote Don't spit into the well, you might drink from it later. -----Yiddish ProverbGlossy Galaxy Ball---How to Make FoliageMy Gallery PDN Fans--My DA Link to comment Share on other sites More sharing options...
Myrddin Posted March 3, 2009 Share Posted March 3, 2009 I'm terribly sorry, with a title like that, I was inches away from locking this as spam. Additional to HELEN's advice, you could also try the Smudge plugin. Although, it should be used carefully so not to distort the feature and/or background too much. There is also another plugin that enabled the user to morph an image at will, à la Photoshop's Liquify, but I cannot seem to find it at the present time. (No, it was not Mike's April Fools' joke.) Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
OhZone Posted March 4, 2009 Author Share Posted March 4, 2009 You can try this and select the nose and enlarge it. Just follow the steps and you'll get a very good effect. Appreciate the help guys. But your link says this.... "Now rectangle select the eye again and shink and move it to where u want it on the face" So, um... HOW DO YOU SHRINK? Doesn't say that. Quote Link to comment Share on other sites More sharing options...
someone93 Posted March 4, 2009 Share Posted March 4, 2009 If you want to enlarge that part, make the selection bigger. Use , grab a corner nub, hold shift to keep the ratio (shape) of it, then drag it to the desired size. Quote Link to comment Share on other sites More sharing options...
OhZone Posted March 4, 2009 Author Share Posted March 4, 2009 If you want to enlarge that part, make the selection bigger.Use , grab a corner nub, hold shift to keep the ratio (shape) of it, then drag it to the desired size. GREAT! Thanks. So one can change size with the Selects and move tools. Also for more subtle, someone said you can use budge. Thanks again! Quote Link to comment Share on other sites More sharing options...
