Modify Default "Fit Picture To Frame"?
Go to solution Solved by Rick Brewster,
When printing a picture, the default is to automatically "Fit Picture to Frame," ie, enlarge it to whatever size of paper it's being printed on.
I do a LOT of printing to PDFs, and have to turn this off on every layer, 5-6 times per file.
Is there a way to set the default on this to "Do NOT Fit Picture to Frame?" It would save me, on average, 6 clicks per project, roughly 40 projects per weekend. And that many clicks DOES make a difference for my poor fingers.
  • Solution
Unfortunately this isn't possible, as the printing UI is a Windows component. There's no way for me to make any changes to its UI -- I'd have to write a brand new printing UI and printing system from scratch. Someday...
Oh, well. Somebody send me some magnesium oil to dull the pain.... as you say, SOMEDAY.
