Right Click erase for the Pencil tool
Go to solution Solved by BoltBait,
  • Solution
Right-clicking with the pencil tool gives you the secondary color.
So, just put your transparent color into your secondary slot, change your pencil tool to "Overwrite" blending and you're all set:
  • Upvote 2
  • You're a Smart Cookie! 1
Click to play:
