Precisely moving text entry bar using arrow keys, possible?
There is a 'move selected pixels' tool that lets you move selected pixels with the arrow keys and tells you the precise location of the 'selection top left' in coordinates at bottom left of the application window. Is there something equivalent for the text entry bar, so you could move it with the arrow keys pixel by pixel and see where it is? It seems you're forced to move it by hand, while watching 'anchor point' on bottom left of application. When you're dealing with a high res image, say 4000X4000 or more, precise placement by hand is awkward.
Edited by michaelibrown
  • 4 months later...
