WinnythailandFX Posted September 27, 2021 Share Posted September 27, 2021 i don't know why, paint.net 4.3 is not responding when i open it for some reason, after i reinstall it, still not responding (even restart my pc) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 27, 2021 Share Posted September 27, 2021 Do you have a lot of plugins installed? Something like this could potentially happen if you have a lot of old plugins, an antivirus other than Defender installed, a slow/older CPU, and a hard drive (not an SSD). To troubleshoot, you can first try running Paint.NET without plugins by going to Start->Run (press WinKey+R), and use it to launch paintdotnet:/disablePlugins If that helps, it's definitely due to plugins. We can troubleshoot further from there. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 27, 2021 Share Posted September 27, 2021 I just pushed 4.3.1, see if that helps Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
WinnythailandFX Posted September 28, 2021 Author Share Posted September 28, 2021 (edited) Well, look like My computer didn't like newest version of paint.net for some reason. and yes, i have plugins installed and i try to disable it, but paint.net wouldn't let me disable then here a clip for a proof: note: i have to downgrade paint net 4.3 to paint 4.2 to open then. Edited September 28, 2021 by WinnythailandFX Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted September 28, 2021 Share Posted September 28, 2021 @WinnythailandFX, Please post the diagnostic information found within Paint.NET; even if it's from Paint.net v4.2.16. Settings -> Diagnostics -> Copy to clipboard Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
WinnythailandFX Posted September 28, 2021 Author Share Posted September 28, 2021 well, here you go sir! Application paint.net 4.2.15 (Final 4.215.7694.37221) Build Date 24 มกราคม 2564 (january 24, 2021) Install type Classic Hardware accelerated rendering (GPU) True Animations True DPI 96 (1.00x scale) Language en-US OS Windows 10 Home Single Language x64 (10.0.19043.0) (0x64) .NET Runtime 4.0.30319.42000 Physical Memory 8,109 MB CPU Intel(R) Core(TM) i3-8130U CPU @ 2.20GHz Speed ~2208 MHz Cores / Threads 2 / 4 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2 Video Card NVIDIA GeForce MX130 Dedicated Video RAM 2,010 MB Dedicated System RAM 0 MB Shared System RAM 4,054 MB Vendor ID 0x10DE Device ID 0x174D Subsystem ID 0x12861025 Revision 162 LUID 0x0000C9E7 Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 1 Feature Level Direct3D_11_0 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Intel(R) UHD Graphics 620 Dedicated Video RAM 128 MB Dedicated System RAM 0 MB Shared System RAM 4,054 MB Vendor ID 0x8086 Device ID 0x5917 Subsystem ID 0x12861025 Revision 7 LUID 0x0000A5BC Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption TriangleBoundary Compute Preemption ThreadBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 4,054 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000C9B4 Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Managed assemblies 62 mscorlib mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet PaintDotNet, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Core PaintDotNet.Core, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Base PaintDotNet.Base, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null WindowsBase WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Core System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Drawing System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 PresentationCore PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet.SystemLayer PaintDotNet.SystemLayer, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Framework PaintDotNet.Framework, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Resources PaintDotNet.Resources, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Effects PaintDotNet.Effects, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Data PaintDotNet.Data, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.SystemLayer.Native.x64 PaintDotNet.SystemLayer.Native.x64, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null System.Configuration System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Xml System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Xaml System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Runtime.CompilerServices.Unsafe System.Runtime.CompilerServices.Unsafe, Version=4.0.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a WebPFileType WebPFileType, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null AvifFileType AvifFileType, Version=1.1.6.0, Culture=neutral, PublicKeyToken=null DdsFileTypePlus DdsFileTypePlus, Version=1.10.7.0, Culture=neutral, PublicKeyToken=null System.Collections.Immutable System.Collections.Immutable, Version=1.2.5.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Buffers System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Memory System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 CodeLab CodeLab, Version=6.3.7940.34205, Culture=neutral, PublicKeyToken=null Alpha2Gray Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null BandWPlus BandWPlus, Version=1.1.6909.27136, Culture=neutral, PublicKeyToken=null OutlinedGradientText OutlinedGradientText, Version=1.1.6826.41783, Culture=neutral, PublicKeyToken=null Burninate Burninate, Version=4.5.6827.39185, Culture=neutral, PublicKeyToken=null Calendar Calendar, Version=4.6.6909.25747, Culture=neutral, PublicKeyToken=null ColorBalance ColorBalance, Version=4.5.6832.41698, Culture=neutral, PublicKeyToken=null Dimensions Dimensions, Version=1.3.6826.38472, Culture=neutral, PublicKeyToken=null Dream Dream, Version=4.5.6832.41729, Culture=neutral, PublicKeyToken=null FillFromClipboard FillFromClipboard, Version=4.6.6909.25430, Culture=neutral, PublicKeyToken=null FillFromFile FillFromFile, Version=4.6.6909.24920, Culture=neutral, PublicKeyToken=null Flip Flip, Version=4.5.6832.41809, Culture=neutral, PublicKeyToken=null FloydSteinbergDithering FloydSteinbergDithering, Version=4.5.6828.38953, Culture=neutral, PublicKeyToken=null GaussianBlurPlus GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null Gray2Alpha Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null GridCheckerboard GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null HSVGradients HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null HueSatPlus HueSatPlus, Version=4.5.6832.41926, Culture=neutral, PublicKeyToken=null Landscape Landscape, Version=4.5.6826.38591, Culture=neutral, PublicKeyToken=null LevelHorizon LevelHorizon, Version=4.5.6826.37471, Culture=neutral, PublicKeyToken=null MemeMaker MemeMaker, Version=4.5.6828.38061, Culture=neutral, PublicKeyToken=null ObjectTools ObjectTools, Version=4.5.6832.42044, Culture=neutral, PublicKeyToken=null OilPaintingPlus OilPaintingPlus, Version=4.5.6832.21777, Culture=neutral, PublicKeyToken=null Feather Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null PasteAlpha PasteAlpha, Version=4.5.6826.36532, Culture=neutral, PublicKeyToken=null Pastel Pastel, Version=4.5.6832.42132, Culture=neutral, PublicKeyToken=null PhotoAdjustments PhotoAdjustments, Version=4.5.6826.37237, Culture=neutral, PublicKeyToken=null Polygon Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null RemoveDust RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null SeamCarving SeamCarving, Version=4.5.6838.35770, Culture=neutral, PublicKeyToken=null SelectionTools SelectionTools, Version=4.5.6832.22117, Culture=neutral, PublicKeyToken=null Temperature Temperature, Version=4.5.6832.41128, Culture=neutral, PublicKeyToken=null Transparency Transparency, Version=4.5.6832.41213, Culture=neutral, PublicKeyToken=null VignettePlus VignettePlus, Version=4.5.6826.39332, Culture=neutral, PublicKeyToken=null System.IO.Compression System.IO.Compression, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 Native modules 127 PaintDotNet.exe C:\Program Files\paint.net\PaintDotNet.exe, version=4.215.7694.37221 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1023 (WinBuild.160101.0800) MSCOREE.DLL C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.19041.1 (WinBuild.160101.0800) KERNEL32.dll C:\WINDOWS\System32\KERNEL32.dll, version=10.0.19041.1151 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1151 (WinBuild.160101.0800) apphelp.dll C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800) ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) mscoreei.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4180.0 built by: NET48REL1LAST_B SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) VERSION.dll C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) clr.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.8.4400.0 built by: NET48REL1LAST_C USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1237 (WinBuild.160101.0800) VCRUNTIME140_CLR0400.dll C:\WINDOWS\SYSTEM32\VCRUNTIME140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.1202 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1110 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase_clr0400.dll C:\WINDOWS\SYSTEM32\ucrtbase_clr0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) psapi.dll C:\WINDOWS\System32\psapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) mscorlib.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\97c421700557a331a31041b81ac3b698\mscorlib.ni.dll, version=4.8.4400.0 built by: NET48REL1LAST_C ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1202 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.1202 (WinBuild.160101.0800) bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1202 (WinBuild.160101.0800) uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) CRYPTBASE.dll C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\372e9962a41f186f070f1cb9f93273ee\System.ni.dll, version=4.8.4360.0 built by: NET48REL1LAST_C System.Core.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\dbf675a2e7564fd29ec8b82b29a1a2fe\System.Core.ni.dll, version=4.8.4390.0 built by: NET48REL1LAST_C WindowsBase.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\909b8ff6c817761576c6ca98a16e38a3\WindowsBase.ni.dll, version=4.8.4390.0 built by: NET48REL1LAST_C System.Drawing.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\d4da288bf6ac86ce3921b8db5eaed5be\System.Drawing.ni.dll, version=4.8.4390.0 built by: NET48REL1LAST_C PresentationCore.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\0fac2f53578a7245ab0fafe2716a42af\PresentationCore.ni.dll, version=4.8.4390.0 built by: NET48REL1LAST_C PresentationFramework.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\d8fa23fbed69ed7835374d74f1e953d1\PresentationFramework.ni.dll, version=4.8.4390.0 PaintDotNet.Base.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\501ec572c5c4a1c9f10e59239a24deb5\PaintDotNet.Base.ni.dll, version=4.215.7694.37221 System.Windows.Forms.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\deafeb5fb937036cb4c6368810108091\System.Windows.Forms.ni.dll, version=4.8.4400.0 built by: NET48REL1LAST_C PaintDotNet.SystemLayer.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\820fbf683d2c9706448fc91c0f998580\PaintDotNet.SystemLayer.ni.dll, version=4.215.7694.37221 PaintDotNet.Core.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\60905194353b18349959b85fc0696e03\PaintDotNet.Core.ni.dll, version=4.215.7694.37221 PaintDotNet.Resources.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\414728d392c0180ccba87a2539b0a795\PaintDotNet.Resources.ni.dll, version=4.215.7694.37221 PaintDotNet.Framework.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\43037004b160e733ae1d68ab84e06e19\PaintDotNet.Framework.ni.dll, version=4.215.7694.37221 PaintDotNet.Data.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\ea83a2b833ee2d5fc49ca629b3c8becd\PaintDotNet.Data.ni.dll, version=4.215.7694.37221 PaintDotNet.Effects.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\bbabaa730ce14d03f3b74d586e596583\PaintDotNet.Effects.ni.dll, version=4.215.7694.37221 PaintDotNet.ni.exe C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\353346a93f6058bf81307e0bc8b5f805\PaintDotNet.ni.exe, version=4.215.7694.37221 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) wpfgfx_v0400.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.8.4390.0 built by: NET48REL1LAST_C OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) MSVCP140_CLR0400.dll C:\WINDOWS\SYSTEM32\MSVCP140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM PresentationNative_v0400.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.8.4390.0 built by: NET48REL1LAST_C shell32.dll C:\WINDOWS\System32\shell32.dll, version=10.0.19041.964 (WinBuild.160101.0800) windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800) vcruntime140.dll C:\Program Files\paint.net\Native\X64\vcruntime140.dll, version=14.28.29334.0 built by: vcwrkspc vcruntime140_1.dll C:\Program Files\paint.net\Native\X64\vcruntime140_1.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140.dll C:\Program Files\paint.net\Native\X64\msvcp140.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_1.dll C:\Program Files\paint.net\Native\X64\msvcp140_1.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_2.dll C:\Program Files\paint.net\Native\X64\msvcp140_2.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_codecvt_ids.dll C:\Program Files\paint.net\Native\X64\msvcp140_codecvt_ids.dll, version=14.28.29334.0 built by: vcwrkspc vcomp140.dll C:\Program Files\paint.net\Native\X64\vcomp140.dll, version=14.28.29334.0 built by: vcwrkspc PaintDotNet.SystemLayer.Native.x64.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\a379d6056ae84eefdf7070568bba32e7\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.215.7694.37221 PaintDotNet.SystemLayer.Native.x64.dll C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.215.7694.37221 PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1151_none_91a40286cc884949\gdiplus.dll, version=10.0.19041.1151 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1151 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) System.Configuration.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\053d057c90af827d0929a6aba7feabcf\System.Configuration.ni.dll, version=4.8.4190.0 built by: NET48REL1LAST_B msasn1.dll C:\WINDOWS\SYSTEM32\msasn1.dll, version=10.0.19041.546 (WinBuild.160101.0800) cryptnet.dll C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Xml.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\eab83bdd6eee1b956e2c8aef88914cc1\System.Xml.ni.dll, version=4.8.4084.0 built by: NET48REL1 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) clrjit.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.8.4400.0 built by: NET48REL1LAST_C System.Xaml.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\ee8292bafc8ef101417cac0e811181ae\System.Xaml.ni.dll, version=4.8.4390.0 built by: NET48REL1LAST_C MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Runtime.CompilerServices.Unsafe.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\5450d06f73fac743e09f663bb997f296\System.Runtime.CompilerServices.Unsafe.ni.dll, version=4.700.20.12001 dxgi.dll C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.964 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1151 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.844 (WinBuild.160101.0800) TextShaping.dll C:\WINDOWS\System32\TextShaping.dll, version= WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.1 (WinBuild.160101.0800) d2d1.dll C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.1202 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Collections.Immutable.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Coll4a4f96a7#\d80ffd609b5dfe702dafb1f7380b2402\System.Collections.Immutable.ni.dll, version=4.700.20.21406 dwmapi.dll C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1151 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1237 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Buffers.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Buffers\56e9d3cf0956fcebcb6a38e493c9f5ff\System.Buffers.ni.dll, version=4.6.28619.01 textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1202 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= winmm.dll C:\WINDOWS\SYSTEM32\winmm.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Memory.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Memory\5bd58fef616d9d05f45d9a5cfea495e9\System.Memory.ni.dll, version=4.6.28619.01 explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800) diasymreader.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.8.4084.0 built by: NET48REL1 nvldumdx.dll C:\WINDOWS\System32\DriverStore\FileRepository\nvae.inf_amd64_6f9c85b5880393c8\nvldumdx.dll, version=27.21.14.6660 WINTRUST.DLL C:\WINDOWS\System32\WINTRUST.DLL, version=10.0.19041.1237 (WinBuild.160101.0800) imagehlp.dll C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.546 (WinBuild.160101.0800) nvwgf2umx.dll C:\WINDOWS\System32\DriverStore\FileRepository\nvae.inf_amd64_6f9c85b5880393c8\nvwgf2umx.dll, version=27.21.14.6660 nvspcap64.dll C:\WINDOWS\system32\nvspcap64.dll, version=3.20.5.70 igd10iumd64.dll C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igd10iumd64.dll, version=27.20.100.8681 ncrypt.dll C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) NTASN1.dll C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800) igdgmm64.dll C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igdgmm64.dll, version=27.20.100.8681 igc64.dll C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igc64.dll, version=27.20.100.8681 System.IO.Compression.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.IO.Cb3b124c8#\ad0763ff8133b8768ec46e7a47a06a3e\System.IO.Compression.ni.dll, version=4.8.4084.0 built by: NET48REL1 SetupApi.dll C:\WINDOWS\System32\SetupApi.dll, version=10.0.19041.1 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1151 (WinBuild.160101.0800) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 30, 2021 Share Posted September 30, 2021 Looks like this is the same issue reported here: Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 4, 2021 Share Posted October 4, 2021 4.3.2 is out with the fix: Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
petran79 Posted October 16, 2021 Share Posted October 16, 2021 I have the same issue but this time application opens normally. Yet if I try to open an image and resize it or copy-paste it to another image, paint.net freezes. Notice that eg when I click resize, the window appears for half a second, dissapears for a few seconds and then appears permanently. Yet the moment I try to edit any parameters, it freezes. Tried disabling hardware acceleration, same thing. Do not have any external plugins installed either. This did not occur in previous versions here is the log Application paint.net 4.3.2 (Stable 4.302.7947.34042) Build Date Monday, 4 October, 2021 Install type Classic Επιτάχυνση γραφικών μέσω υλικού (GPU) False Κινούμενη Εικόνα True DPI 96 (1,00x scale) Γλώσσα el-GR OS Windows 10 Home x64 (10.0.19043.0) Runtime .NET 5.0.10 x64 Physical Memory 16.345 MB CPU Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz Speed ~2592 MHz Cores / Threads 4 / 8 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2 Video Card NVIDIA GeForce GTX 1060 Dedicated Video RAM 6.052 MB Dedicated System RAM 0 MB Shared System RAM 8.172 MB Vendor ID 0x10DE Device ID 0x1C60 Subsystem ID 0x825F103C Revision 161 LUID 0x00B06EC1 Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption PixelBoundary Compute Preemption DispatchBoundary Outputs 1 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 8.172 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x000195F7 Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Managed assemblies 79 System.Private.CoreLib System.Private.CoreLib, Version=5.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e paintdotnet paintdotnet, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.Runtime System.Runtime, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms System.Windows.Forms, Version=5.0.10.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet.Base PaintDotNet.Base, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.Diagnostics.Process System.Diagnostics.Process, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer PaintDotNet.SystemLayer, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.Runtime.InteropServices.RuntimeInformation System.Runtime.InteropServices.RuntimeInformation, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.IO.FileSystem System.IO.FileSystem, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer.Native.x64 PaintDotNet.SystemLayer.Native.x64, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.Threading System.Threading, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions System.Runtime.Extensions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.InteropServices System.Runtime.InteropServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC System.Runtime.CompilerServices.VisualC, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric System.Collections.NonGeneric, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Intrinsics System.Runtime.Intrinsics, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections System.Collections, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Memory System.Memory, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Core PaintDotNet.Core, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.Private.Uri System.Private.Uri, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives System.ComponentModel.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a WindowsBase WindowsBase, Version=5.0.10.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms.Primitives System.Windows.Forms.Primitives, Version=5.0.10.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Drawing.Primitives System.Drawing.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives Microsoft.Win32.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource System.Diagnostics.TraceSource, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages System.Text.Encoding.CodePages, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager System.Configuration.ConfigurationManager, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Threading.Thread System.Threading.Thread, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Resources PaintDotNet.Resources, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.ObjectModel System.ObjectModel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Specialized System.Collections.Specialized, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data PaintDotNet.Data, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null PaintDotNet.Framework PaintDotNet.Framework, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null System.Private.Xml System.Private.Xml, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Drawing.Common System.Drawing.Common, Version=5.0.0.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Immutable System.Collections.Immutable, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Net.WebClient System.Net.WebClient, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq System.Linq, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents Microsoft.Win32.SystemEvents, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Cryptography.Algorithms System.Security.Cryptography.Algorithms, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Concurrent System.Collections.Concurrent, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Registry Microsoft.Win32.Registry, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.EventBasedAsync System.ComponentModel.EventBasedAsync, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework PresentationFramework, Version=5.0.10.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 netstandard netstandard, Version=2.1.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Principal.Windows System.Security.Principal.Windows, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter System.ComponentModel.TypeConverter, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Xml.ReaderWriter System.Xml.ReaderWriter, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Threading.ThreadPool System.Threading.ThreadPool, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Security.Claims System.Security.Claims, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.Extensions System.Text.Encoding.Extensions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel System.ComponentModel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Xaml System.Xaml, Version=5.0.10.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PresentationCore PresentationCore, Version=5.0.10.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder DirectWriteForwarder, Version=5.0.10.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.FileVersionInfo System.Diagnostics.FileVersionInfo, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects PaintDotNet.Effects, Version=4.302.7947.34042, Culture=neutral, PublicKeyToken=null Accessibility Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Threading.Tasks.Parallel System.Threading.Tasks.Parallel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.IO.Packaging System.IO.Packaging, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a mscorlib mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Diagnostics.Debug System.Diagnostics.Debug, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Security.Principal System.Security.Principal, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader System.Runtime.Loader, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a AvifFileType AvifFileType, Version=1.1.15.0, Culture=neutral, PublicKeyToken=null WebPFileType WebPFileType, Version=1.3.7.0, Culture=neutral, PublicKeyToken=null DdsFileTypePlus DdsFileTypePlus, Version=1.10.10.0, Culture=neutral, PublicKeyToken=null System.Buffers System.Buffers, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Diagnostics.Tracing System.Diagnostics.Tracing, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Formatters System.Runtime.Serialization.Formatters, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.CodeDom System.CodeDom, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.RegularExpressions System.Text.RegularExpressions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Numerics.Vectors System.Numerics.Vectors, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.Unsafe System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.StackTrace System.Diagnostics.StackTrace, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.Metadata System.Reflection.Metadata, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext System.Reflection.MetadataLoadContext, Version=5.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.IO.Compression System.IO.Compression, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 Native modules 185 paintdotnet.exe C:\Program Files\paint.net\paintdotnet.exe, version=4.302.7947.34042 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1023 (WinBuild.160101.0800) KERNEL32.DLL C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.1151 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1151 (WinBuild.160101.0800) USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.320 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1288 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.1202 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1110 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) SHELL32.dll C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.320 (WinBuild.160101.0800) ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.320 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.320 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.320 (WinBuild.160101.0800) IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) hostfxr.dll C:\Program Files\paint.net\hostfxr.dll, version=5,0,1021,41214 @Commit: e1825b4928afa9455cc51e1de2b2e66c8be3018d hostpolicy.dll C:\Program Files\paint.net\hostpolicy.dll, version=5,0,1021,41214 @Commit: e1825b4928afa9455cc51e1de2b2e66c8be3018d coreclr.dll C:\Program Files\paint.net\coreclr.dll, version=5,0,1021,41214 @Commit: e1825b4928afa9455cc51e1de2b2e66c8be3018d ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1266 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.1202 (WinBuild.160101.0800) OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1202 (WinBuild.160101.0800) System.Private.CoreLib.dll C:\Program Files\paint.net\System.Private.CoreLib.dll, version=5.0.1021.41214 clrjit.dll C:\Program Files\paint.net\clrjit.dll, version=5,0,1021,41214 @Commit: e1825b4928afa9455cc51e1de2b2e66c8be3018d kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) paintdotnet.dll C:\Program Files\paint.net\paintdotnet.dll, version=4.302.7947.34042 System.Runtime.dll C:\Program Files\paint.net\System.Runtime.dll, version=5.0.1021.41214 wbload.dll C:\WINDOWS\system32\wbload.dll, version=10.8.5.0 UxTheme.dll C:\WINDOWS\system32\UxTheme.dll, version=10.0.19041.320 (WinBuild.160101.0800) WBLIND64.dll C:\Program Files (x86)\Stardock\WindowBlinds\WBLIND64.dll, version=10.8.9.0 wbhelp64.dll C:\Program Files (x86)\Stardock\WindowBlinds\wbhelp64.dll, version=4.01 Dock64.dll C:\Program Files (x86)\Stardock\ObjectDock\Dock64.dll, version=2.10.0.810 ListaryHook64.dll C:\Program Files\Listary\ListaryHook64.dll, version=5.0.2334.0 SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.320 (WinBuild.160101.0800) COMCTL32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.19041.1110_none_792d1c772443f647\COMCTL32.dll, version=5.82 (WinBuild.160101.0800) OLEACC.dll C:\WINDOWS\SYSTEM32\OLEACC.dll, version=7.2.19041.746 (WinBuild.160101.0800) Start10_64.dll C:\Program Files (x86)\Stardock\Start10\Start10_64.dll, version=1.9.7.0 FencesMenu64.dll C:\Program Files (x86)\Stardock\Fences\FencesMenu64.dll, version=3.1.3.3 USERENV.dll C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.320 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1288_none_91a663c8cc864906\gdiplus.dll, version=10.0.19041.1288 (WinBuild.160101.0800) WTSAPI32.dll C:\WINDOWS\SYSTEM32\WTSAPI32.dll, version=10.0.19041.546 (WinBuild.160101.0800) wfx4_64.dll C:\Program Files (x86)\Stardock\WindowFX\wfx4_64.dll, version=6.1.2.0 dwmapi.dll C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.19041.320 (WinBuild.160101.0800) System.Windows.Forms.dll C:\Program Files\paint.net\System.Windows.Forms.dll, version=5.0.1021.41806 PaintDotNet.Base.dll C:\Program Files\paint.net\PaintDotNet.Base.dll, version=4.302.7947.34042 icu.dll C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) System.Diagnostics.Process.dll C:\Program Files\paint.net\System.Diagnostics.Process.dll, version=5.0.1021.41214 PaintDotNet.SystemLayer.dll C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll, version=4.302.7947.34042 System.Runtime.InteropServices.RuntimeInformation.dll C:\Program Files\paint.net\System.Runtime.InteropServices.RuntimeInformation.dll, version=5.0.1021.41214 System.IO.FileSystem.dll C:\Program Files\paint.net\System.IO.FileSystem.dll, version=5.0.1021.41214 vcruntime140.dll C:\Program Files\paint.net\vcruntime140.dll, version=14.29.30133.0 built by: vcwrkspc vcruntime140_1.dll C:\Program Files\paint.net\vcruntime140_1.dll, version=14.29.30133.0 built by: vcwrkspc msvcp140.dll C:\Program Files\paint.net\msvcp140.dll, version=14.29.30133.0 built by: vcwrkspc msvcp140_1.dll C:\Program Files\paint.net\msvcp140_1.dll, version=14.29.30133.0 built by: vcwrkspc msvcp140_2.dll C:\Program Files\paint.net\msvcp140_2.dll, version=14.29.30133.0 built by: vcwrkspc msvcp140_codecvt_ids.dll C:\Program Files\paint.net\msvcp140_codecvt_ids.dll, version=14.29.30133.0 built by: vcwrkspc vcomp140.dll C:\Program Files\paint.net\vcomp140.dll, version=14.29.30133.0 built by: vcwrkspc ijwhost.dll C:\Program Files\paint.net\ijwhost.dll, version=5,0,1021,41214 @Commit: e1825b4928afa9455cc51e1de2b2e66c8be3018d PaintDotNet.SystemLayer.Native.x64.dll C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.302.7947.34042 WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1151 (WinBuild.160101.0800) PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.320 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.320 (WinBuild.160101.0800) System.Threading.dll C:\Program Files\paint.net\System.Threading.dll, version=5.0.1021.41214 System.Runtime.Extensions.dll C:\Program Files\paint.net\System.Runtime.Extensions.dll, version=5.0.1021.41214 System.Runtime.InteropServices.dll C:\Program Files\paint.net\System.Runtime.InteropServices.dll, version=5.0.1021.41214 System.Runtime.CompilerServices.VisualC.dll C:\Program Files\paint.net\System.Runtime.CompilerServices.VisualC.dll, version=5.0.1021.41214 System.Collections.NonGeneric.dll C:\Program Files\paint.net\System.Collections.NonGeneric.dll, version=5.0.1021.41214 System.Runtime.Intrinsics.dll C:\Program Files\paint.net\System.Runtime.Intrinsics.dll, version=5.0.1021.41214 windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.320 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.320 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.320 (WinBuild.160101.0800) System.Collections.dll C:\Program Files\paint.net\System.Collections.dll, version=5.0.1021.41214 System.Memory.dll C:\Program Files\paint.net\System.Memory.dll, version=5.0.1021.41214 PaintDotNet.Core.dll C:\Program Files\paint.net\PaintDotNet.Core.dll, version=4.302.7947.34042 System.Private.Uri.dll C:\Program Files\paint.net\System.Private.Uri.dll, version=5.0.1021.41214 System.ComponentModel.Primitives.dll C:\Program Files\paint.net\System.ComponentModel.Primitives.dll, version=5.0.1021.41214 WindowsBase.dll C:\Program Files\paint.net\WindowsBase.dll, version=5.0.1021.41814 System.Windows.Forms.Primitives.dll C:\Program Files\paint.net\System.Windows.Forms.Primitives.dll, version=5.0.1021.41806 System.Drawing.Primitives.dll C:\Program Files\paint.net\System.Drawing.Primitives.dll, version=5.0.1021.41214 Microsoft.Win32.Primitives.dll C:\Program Files\paint.net\Microsoft.Win32.Primitives.dll, version=5.0.1021.41214 System.Diagnostics.TraceSource.dll C:\Program Files\paint.net\System.Diagnostics.TraceSource.dll, version=5.0.1021.41214 System.Text.Encoding.CodePages.dll C:\Program Files\paint.net\System.Text.Encoding.CodePages.dll, version=5.0.1021.41214 System.Configuration.ConfigurationManager.dll C:\Program Files\paint.net\System.Configuration.ConfigurationManager.dll, version=5.0.20.51904 System.Threading.Thread.dll C:\Program Files\paint.net\System.Threading.Thread.dll, version=5.0.1021.41214 PaintDotNet.Resources.dll C:\Program Files\paint.net\PaintDotNet.Resources.dll, version=4.302.7947.34042 System.ObjectModel.dll C:\Program Files\paint.net\System.ObjectModel.dll, version=5.0.1021.41214 System.Collections.Specialized.dll C:\Program Files\paint.net\System.Collections.Specialized.dll, version=5.0.1021.41214 PaintDotNet.Data.dll C:\Program Files\paint.net\PaintDotNet.Data.dll, version=4.302.7947.34042 PaintDotNet.Framework.dll C:\Program Files\paint.net\PaintDotNet.Framework.dll, version=4.302.7947.34042 System.Private.Xml.dll C:\Program Files\paint.net\System.Private.Xml.dll, version=5.0.1021.41214 System.Drawing.Common.dll C:\Program Files\paint.net\System.Drawing.Common.dll, version=5.0.421.11614 System.Collections.Immutable.dll C:\Program Files\paint.net\System.Collections.Immutable.dll, version=5.0.1021.41214 System.Net.WebClient.dll C:\Program Files\paint.net\System.Net.WebClient.dll, version=5.0.1021.41214 System.Linq.dll C:\Program Files\paint.net\System.Linq.dll, version=5.0.1021.41214 Microsoft.Win32.SystemEvents.dll C:\Program Files\paint.net\Microsoft.Win32.SystemEvents.dll, version=5.0.20.51904 System.Security.Cryptography.Algorithms.dll C:\Program Files\paint.net\System.Security.Cryptography.Algorithms.dll, version=5.0.1021.41214 System.Collections.Concurrent.dll C:\Program Files\paint.net\System.Collections.Concurrent.dll, version=5.0.1021.41214 Microsoft.Win32.Registry.dll C:\Program Files\paint.net\Microsoft.Win32.Registry.dll, version=5.0.20.51904 System.ComponentModel.EventBasedAsync.dll C:\Program Files\paint.net\System.ComponentModel.EventBasedAsync.dll, version=5.0.1021.41214 PresentationFramework.dll C:\Program Files\paint.net\PresentationFramework.dll, version=5.0.1021.41814 PresentationNative_cor3.dll C:\Program Files\paint.net\PresentationNative_cor3.dll, version=5,0,1021,41603 @Commit: 6f905b6b5d75f2a7157a5c362268aadd24df7773 netstandard.dll C:\Program Files\paint.net\netstandard.dll, version=5.0.1021.41214 System.Security.Principal.Windows.dll C:\Program Files\paint.net\System.Security.Principal.Windows.dll, version=5.0.20.51904 System.ComponentModel.TypeConverter.dll C:\Program Files\paint.net\System.ComponentModel.TypeConverter.dll, version=5.0.1021.41214 System.Xml.ReaderWriter.dll C:\Program Files\paint.net\System.Xml.ReaderWriter.dll, version=5.0.1021.41214 System.Threading.ThreadPool.dll C:\Program Files\paint.net\System.Threading.ThreadPool.dll, version=5.0.1021.41214 System.Security.Claims.dll C:\Program Files\paint.net\System.Security.Claims.dll, version=5.0.1021.41214 System.Text.Encoding.Extensions.dll C:\Program Files\paint.net\System.Text.Encoding.Extensions.dll, version=5.0.1021.41214 dxgi.dll C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.1266 (WinBuild.160101.0800) System.ComponentModel.dll C:\Program Files\paint.net\System.ComponentModel.dll, version=5.0.1021.41214 System.Xaml.dll C:\Program Files\paint.net\System.Xaml.dll, version=5.0.1021.41814 PresentationCore.dll C:\Program Files\paint.net\PresentationCore.dll, version=5.0.1021.41814 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.320 (WinBuild.160101.0800) DirectWriteForwarder.dll C:\Program Files\paint.net\DirectWriteForwarder.dll, version=5,0,1021,41814 @Commit: 34e65b82cfa0c5bfc9f91e164676f62ae9f27bbf System.Diagnostics.FileVersionInfo.dll C:\Program Files\paint.net\System.Diagnostics.FileVersionInfo.dll, version=5.0.1021.41214 PaintDotNet.Effects.dll C:\Program Files\paint.net\PaintDotNet.Effects.dll, version=4.302.7947.34042 Accessibility.dll C:\Program Files\paint.net\Accessibility.dll, version=5.0.1021.41806 System.Threading.Tasks.Parallel.dll C:\Program Files\paint.net\System.Threading.Tasks.Parallel.dll, version=5.0.1021.41214 System.IO.Packaging.dll C:\Program Files\paint.net\System.IO.Packaging.dll, version=5.0.20.51904 mscorlib.dll C:\Program Files\paint.net\mscorlib.dll, version=5.0.1021.41214 CClipboardH64.dll C:\Program Files (x86)\ComfortClipboard\CClipboardH64.dll, version=9.1.0.0 System.Diagnostics.Debug.dll C:\Program Files\paint.net\System.Diagnostics.Debug.dll, version=5.0.1021.41214 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.320 (WinBuild.160101.0800) System.Security.Principal.dll C:\Program Files\paint.net\System.Security.Principal.dll, version=5.0.1021.41214 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) WINMM.dll C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.19041.320 (WinBuild.160101.0800) version.dll C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800) comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.320 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1151 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.320 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.844 (WinBuild.160101.0800) System.Runtime.Loader.dll C:\Program Files\paint.net\System.Runtime.Loader.dll, version=5.0.1021.41214 AvifFileType.dll C:\Program Files\paint.net\Bundled\AvifFileType\AvifFileType.dll, version=1.1.15.0 WebPFileType.dll C:\Program Files\paint.net\Bundled\WebPFileType\WebPFileType.dll, version=1.3.7.0 DdsFileTypePlus.dll C:\Program Files\paint.net\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.10.0 TextShaping.dll C:\WINDOWS\SYSTEM32\TextShaping.dll, version= WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.320 (WinBuild.160101.0800) System.Buffers.dll C:\Program Files\paint.net\System.Buffers.dll, version=5.0.1021.41214 System.Diagnostics.Tracing.dll C:\Program Files\paint.net\System.Diagnostics.Tracing.dll, version=5.0.1021.41214 d2d1.dll C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.320 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.1202 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) UIAutomationCore.dll C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.320 (WinBuild.160101.0800) sxs.dll C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.320 (WinBuild.160101.0800) System.Runtime.Serialization.Formatters.dll C:\Program Files\paint.net\System.Runtime.Serialization.Formatters.dll, version=5.0.1021.41214 System.CodeDom.dll C:\Program Files\paint.net\System.CodeDom.dll, version=5.0.20.51904 dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1151 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1266 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.320 (WinBuild.160101.0800) MSIMG32.dll C:\WINDOWS\SYSTEM32\MSIMG32.dll, version=10.0.19041.546 (WinBuild.160101.0800) textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1266 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.320 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.320 (WinBuild.160101.0800) powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.320 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= System.Text.RegularExpressions.dll C:\Program Files\paint.net\System.Text.RegularExpressions.dll, version=5.0.1021.41214 System.Numerics.Vectors.dll C:\Program Files\paint.net\System.Numerics.Vectors.dll, version=5.0.1021.41214 System.Runtime.CompilerServices.Unsafe.dll C:\Program Files\paint.net\System.Runtime.CompilerServices.Unsafe.dll, version=5.0.1021.41214 explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.320 (WinBuild.160101.0800) Microsoft.DiaSymReader.Native.amd64.dll C:\Program Files\paint.net\Microsoft.DiaSymReader.Native.amd64.dll, version=14.12.25830.2 built by: VCTOOLSD15ULDR System.Diagnostics.StackTrace.dll C:\Program Files\paint.net\System.Diagnostics.StackTrace.dll, version=5.0.1021.41214 System.Reflection.Metadata.dll C:\Program Files\paint.net\System.Reflection.Metadata.dll, version=5.0.1021.41214 System.Reflection.MetadataLoadContext.dll C:\Program Files\paint.net\System.Reflection.MetadataLoadContext.dll, version=5.0.521.16609 System.IO.Compression.dll C:\Program Files\paint.net\System.IO.Compression.dll, version=5.0.1021.41214 SetupApi.dll C:\WINDOWS\System32\SetupApi.dll, version=10.0.19041.320 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1151 (WinBuild.160101.0800) WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.1266 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.320 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800) cryptnet.dll C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800) drvstore.dll C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.19041.1081 (WinBuild.160101.0800) cryptbase.dll C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.19041.546 (WinBuild.160101.0800) imagehlp.dll C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.546 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.320 (WinBuild.160101.0800) psapi.dll C:\WINDOWS\System32\psapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 17, 2021 Share Posted October 17, 2021 @petran79, I suspect all those Stardock utilities you have running are interfering. I would try disabling them and see how Paint.NET runs. Any other "hook" type programs you have installed should also be disabled to see which one might be causing this. ComfortClipboard and Listary show up in the DLL list, for instance. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
