Selection Tools - Feather, Outline, Bevel, Shadow - Upd: 2015-01-31
V3.5 of the plugin does default the color of the outline to the primary color set in pdn.
oh cool, i do actually have that version installed, i wonder what i was doing wrong?
i was seeing a default black color in the plugin, and yet my primary was brown at the time... although, i have just tested this with a new image and it works perfectly.
Edited by ratty redemption
  • 9 months later...
  • 2 years later...
Hey, this is probably a weird bug no one else is getting, but the links to your plug-in pack just bring me to the forums' front page.
I remember getting this plug-in on my previous computer with no issues and it was one of my favorites. :(
Edited by Nas
2 hours ago, Pratyush said:
Hi Boltbait, can you combine all these selection tool i.e. outline, bevel, shadow, feather, gradient fill together as a single plugin. they can be very useful under name of styles.
They are combined into a single DLL called SelectionTools.dll and they all appear under a single menu called Effects > Selection.
  • 5 years later...
28 minutes ago, geogey said:
 why doesn't the bevel selection not work? did i messed up something a bit or no?
"Effects > Selection > Bevel Selection" bevels by following the selection outline (the dashed line).  You have selected the "Keep original alpha" checkbox... therefore the bevel selection will bevel a square and then set the alpha to 0 because you had original alpha of 0 on your selection.
Solution:
Either selection the white areas using the magic wand before running the effect, or run the "Effects > Object > Bevel Object" plugin instead.
Solution:
  • 2 months later...
1 hour ago, UserXtremE said:
Is the bevel plugin having problems? I'm not seeing it in the folder, or in Paint.net, and I really need it for a project.
You need to refresh your plug-ins. Go download this from my latest plug-in pack:
https://forums.getpaint.net/topic/121343-boltbaits-gpu-accelerated-plugin-pack-for-paintnet-v50-updated-2023-07-28/
