PyroTechniques Posted November 19, 2008 Share Posted November 19, 2008 First off - this is an awesome plugin. The best way to 3-D-ize something that I have found so far. I do have a question, however. Not being a programmer, I have no idea if this would be easy or even feasible, but - would it be possible to add some sort of anti-aliasing option in? When I do slanted lines and try to bevel them, I end up with something horribly :AntiAliasingOff:. So, would it be possible to add something like "bevel object" to the Objects menu, that uses the same method as Outline Object to distinguish what the object is, and then bevels it in a :AntiAliasingOn: way? Quote Photobucket Sucks! Link to comment Share on other sites More sharing options...
BoltBait Posted November 19, 2008 Author Share Posted November 19, 2008 First off - this is an awesome plugin. The best way to 3-D-ize something that I have found so far. I do have a question, however. Not being a programmer, I have no idea if this would be easy or even feasible, but - would it be possible to add some sort of anti-aliasing option in? When I do slanted lines and try to bevel them, I end up with something horribly :AntiAliasingOff:. So, would it be possible to add something like "bevel object" to the Objects menu, that uses the same method as Outline Object to distinguish what the object is, and then bevels it in a :AntiAliasingOn: way? First run Bevel, then run Feather. Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
m2lucky Posted January 5, 2009 Share Posted January 5, 2009 this is awesome I was looking for a bevel effect Quote Music Brings color to the world Photobucket Sucks! My Gallery|Frozen Text|Snowy Font|MSNBC Effect Link to comment Share on other sites More sharing options...
himself22 Posted June 7, 2009 Share Posted June 7, 2009 Could you possibly make something for the bevel plugin that would let us choose how solid the colors are, like an alpha slider or something like that? (you can tell I don't program) Thanks. Quote "The truth is just an excuse for having a lack of imagination." Photobucket sucks! Link to comment Share on other sites More sharing options...
BoltBait Posted June 7, 2009 Author Share Posted June 7, 2009 Could you possibly make something for the bevel plugin that would let us choose how solid the colors are, like an alpha slider or something like that?(you can tell I don't program) Thanks. Once you have your selection, add a new layer and run the effect on that new layer. Once you like it, Press OK, then F4 to adjust the layer opacity. That's what I do. Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
Gazek Posted August 22, 2009 Share Posted August 22, 2009 BoltBait, I need the Bevel one.. But I can't find it in your packages. Quote Serious graphics up in that post. Link to comment Share on other sites More sharing options...
BoltBait Posted August 22, 2009 Author Share Posted August 22, 2009 BoltBait, I need the Bevel one.. But I can't find it in your packages. In the plugin pack, it is in a file called SelectionTools.dll Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
avim1968 Posted June 13, 2012 Share Posted June 13, 2012 (edited) Hi BoltBait in your outline selection plugin, you color along the inside line of the selection area. can you add the option to color along the OUTSIDE line of the selection area , without the need to inverse the selection ? question -> can you make any changes to the selection it self or this is something that only Rick can do in his selection code ? thank you Avi Edited June 13, 2012 by avim1968 Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
BoltBait Posted June 13, 2012 Author Share Posted June 13, 2012 Hi BoltBait in your outline selection plugin, you color along the inside line of the selection area. can you add the option to color along the OUTSIDE line of the selection area , without the need to inverse the selection ? I'm afraid that is totally impossible. You see, the Paint.NET plugin system is very strict in regard to the pixels that effects can change. Only selected pixels can be changed. If you tried to change pixels that are not selected, Paint.NET would not allow it. This is a limitation of the plugin system itself. Sorry. Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
avim1968 Posted June 14, 2012 Share Posted June 14, 2012 Hi I see. thank you so I guess that a plugin that can change a selection area is also not possible , right ? Avi Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
null54 Posted June 14, 2012 Share Posted June 14, 2012 Hi I see. thank you so I guess that a plugin that can change a selection area is also not possible , right ? Avi No it is not possible. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
avim1968 Posted June 14, 2012 Share Posted June 14, 2012 thank you. talking about plugins all the time, makes me want to write one myself, can some one point me to a place where i can learn how to make my own plugin? i used to program when i was young, so a place with a simple tutorial and code examples? would be great :-) Avi Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
BoltBait Posted June 14, 2012 Author Share Posted June 14, 2012 thank you. talking about plugins all the time, makes me want to write one myself, can some one point me to a place where i can learn how to make my own plugin? i used to program when i was young, so a place with a simple tutorial and code examples? would be great :-) Avi Start here: http://boltbait.com/pdn/CodeLab/ Install the CodeLab plugin, then go through the tutorials. 1 Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 14, 2012 Share Posted June 14, 2012 Then you could buy the Codelab book - except that I can't convince BoltBait to write it Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Red ochre Posted June 14, 2012 Share Posted June 14, 2012 I'd love to see BoltBait write a codelab book - great talent for succinctly explaining - not assuming the reader is an expert but still not patronising. I'm wonder if Rick/BoltBait could earn a little revenue from PDN's use as both a brilliant graphics program and an educational resource by publishing a small book. It's certainly less intimidating than Visual studio and gives instantly visible (and usuable) results. Being nearly 49 , I'm probably not the target readership but 'our' generation had things like the Commodore 64/ Sinclair etc to play with. I'm sure the kids today must find it hard to get a 'taste' of what programming can do. And a little understanding of how graphics actually work on computers is useful for artists/ illustrators/ designers/ photographers etc etc too. Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
avim1968 Posted June 15, 2012 Share Posted June 15, 2012 Start here: http://boltbait.com/pdn/CodeLab/ Install the CodeLab plugin, then go through the tutorials. WOW what a tutorial !! i could not stop reading it. ! lucky me i used to program in C. & pascal. i just need to install the C# on my computer too. going to play with it and get the hang of it. i'll post when i'll have something to show too or have a question :-) Avi Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
avim1968 Posted June 25, 2012 Share Posted June 25, 2012 Hi BoltBait i have been playing around in codelab, however i'm not able to port/place etc.. the code from codelab into the right place under microsoft visual 2010 C# ? can you tell me how it can be done ? can you point me to a web page ? do you have an example ? thank you Avi Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 25, 2012 Share Posted June 25, 2012 The place to ask that is the Codelab thread surely? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
avim1968 Posted June 26, 2012 Share Posted June 26, 2012 Thanks Ego can you point me to the correct forum ? for some reason i can only see advance codelab but not beginners where such question can be asked? Avi Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 27, 2012 Share Posted June 27, 2012 That's the right one http://forums.getpai...advanced-users/ Or how about having a look in here: http://forums.getpaint.net/index.php?/forum/17-plugin-developers-central/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 2, 2013 Share Posted September 2, 2013 @BoltBait: Thank you for Bevel Selection! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 18, 2014 Share Posted January 18, 2014 I'd really like it if Bevel Selection had a wider range. The current limit is 50. Any reason why it couldn't be raised to 100? Pretty please?? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
ratty redemption Posted April 4, 2014 Share Posted April 4, 2014 hi boltbait, is it possible for your outline selection to include an option to use the primary or secondary colors in pdn? Quote ratty redemption deviantart.com Link to comment Share on other sites More sharing options...
