Prorok Posted May 1, 2019 Share Posted May 1, 2019 Need help finding a plugin. Which copies transparency(Alpha) from one picture and superimposes it on another. "Channel SWAP" Do not offer, he does transparency(Alpha) too much.The picture was originally.After editingWhen you try to copy transparency(Alpha), it becomes too transparent. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 1, 2019 Share Posted May 1, 2019 If you have my plugin pack installed, you have it. Effects > Object > Paste Alpha. Just be sure you alpha is on the clipboard. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Prorok Posted May 1, 2019 Author Share Posted May 1, 2019 Thanks man! 1 hour ago, BoltBait said: If you have my plugin pack installed, you have it. Effects > Object > Paste Alpha. Just be sure you alpha is on the clipboard. Quote Link to comment Share on other sites More sharing options...
