EDOARDOMASTER Posted September 17, 2018 Share Posted September 17, 2018 This is a problem that really bugs me, anytime I use a plugin effect, it just sets the color with transparency. I know this looks like a plugin issue, but it occurs me with every single one. As you can see here, my primary color it is setted to be 000000 with alpha at 255 But in here, it isn't at 255. Clicking the reset button, doesn't do the trick. Is there any known solution for this issue? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 17, 2018 Share Posted September 17, 2018 This will be fixed in the next release of Paint.NET. It is just a visual anomaly. Until then, the colorwheel doesn't have an alpha slider, so the swatch is wrong. The effect will work properly. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
EDOARDOMASTER Posted September 17, 2018 Author Share Posted September 17, 2018 Just now, BoltBait said: This will be fixed in the next release of Paint.NET. Didn't knew it was a known issue! Thanks for the quick response ^^ Quote Link to comment Share on other sites More sharing options...
