gasponce Posted September 11, 2018 Share Posted September 11, 2018 Hello! I've been having this problem while saving at an existing dpi (for example 150dpi) on Paint.net when I try to upload it to various pod sites that I use they Informed me that it shows "bigger" dpi. So I did a check and opened my files with a different program and it seems that no matter what changes I make on Paint to the dpi they don't apply! For example the image bellow opened in photoshop and inkscape has a dpi of 381, but is saved with dpi 150! Any help is welcome! Quote Link to comment Share on other sites More sharing options...
Zagna Posted September 11, 2018 Share Posted September 11, 2018 (edited) You have it set to pixels per centimeter. DPI means dots per inch. So change it to pixels/inch. Edited September 11, 2018 by Zagna 1 1 Quote Link to comment Share on other sites More sharing options...
gasponce Posted September 11, 2018 Author Share Posted September 11, 2018 That is not an option either ppi or dpi doesn't make a difference the "settings" are the same "pixels/cm" or "pixels/inch" Quote Link to comment Share on other sites More sharing options...
gasponce Posted September 11, 2018 Author Share Posted September 11, 2018 Never mind I saw the settings it was on pixels/cm !!! That's why it was screwing me over the whole time!!! Thank you! Quote Link to comment Share on other sites More sharing options...
