help remove noise from raw photos
The built-in Surface Blur tends to solve this sort of problem with relative degrees of success depending on the effect's settings and picture quality, though sometimes the result looks rather unnatural and therefore unsatisfactory. If the noise is too evident, I'm afraid it would be better to consider the possibility of taking a new picture with a better quality (remember that the quality of the camera you use has a lot to do with this). You can also try Smart Blur, which is part of this pack.
3 hours ago, AndrewDavid said:
The image you posted was in the JPG format.
I copied and saved as a PNG and applied the built-in Reduce Noise effect at default settings and came up with this improvement,
See what you think
At this point I do not see any room for improvement. But i am not a professional :)
Hi the photo I uploaded is a jpg as I was not able to upload the 100mb raw. Tryed the built in plugin bu luck.
Hi I not sure what happened on day but all the photos look like that very noisey. I was able to save same not many.  I tryed the blur in paint.net but not smart blur.
