erissimaco Posted October 3, 2017 Share Posted October 3, 2017 (edited) Hello to all,I downloaded the latest version of paint.NET. but when I run the executable this message appears: Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra sono riportate in fondo al messaggio. ************** Testo dell'eccezione ************** PaintDotNet.Direct2D.NoHardwareDeviceException (0x8899000B): ..\Direct2D\D2DFactory.cpp (95) : hr = m_pFactory->CreateDCRenderTarget( &NativeConversions::ToNative(renderTargetProperties), &spDCRenderTarget); (PaintDotNet.Controls.PdnBanner) in PaintDotNet.Interop.InteropErrorInfo.ThrowIfError() in D:\src\pdn\src\Base\Interop\InteropErrorInfo.cs:riga 89 in PaintDotNet.SystemLayer.Native.x64.NativeUtilities.ThrowOnErrorImpl(Int32 hr, SByte* szHr, IUnknown* pFxErrorInfo) in PaintDotNet.SystemLayer.Native.x64.Direct2D.D2DFactory.CreateDCRenderTarget(RenderTargetProperties renderTargetProperties) in PaintDotNet.Direct2D.Proxies.Direct2DFactoryProxy.CreateDCRenderTarget(RenderTargetProperties renderTargetProps) in D:\src\pdn\src\Base\Direct2D\Proxies\Direct2DFactoryProxy.cs:riga 75 in PaintDotNet.Controls.Direct2DControlHandler.RecreateRenderTarget(Boolean invalidateControl) in D:\src\pdn\src\Framework\Controls\Direct2DControlHandler.cs:riga 426 in PaintDotNet.Controls.Direct2DControlHandler.RelayGdiPaintImpl(GdiPaintContext ctx) in D:\src\pdn\src\Framework\Controls\Direct2DControlHandler.cs:riga 500 in PaintDotNet.Controls.Direct2DControlHandler.RelayGdiPaint(GdiPaintContext ctx) in D:\src\pdn\src\Framework\Controls\Direct2DControlHandler.cs:riga 483 in PaintDotNet.Controls.Direct2DControl.OnGdiPaint(GdiPaintContext ctx) in D:\src\pdn\src\Framework\Controls\Direct2DControl.cs:riga 347 in PaintDotNet.SystemLayer.GdiPaintHandler.OnWmPaint(Message& m) in D:\src\pdn\src\SystemLayer\GdiPaintHandler.cs:riga 184 in PaintDotNet.SystemLayer.GdiPaintHandler.RelayWndProc(Message& m) in D:\src\pdn\src\SystemLayer\GdiPaintHandler.cs:riga 233 in PaintDotNet.SystemLayer.GdiPaintControl.WndProc(Message& m) in D:\src\pdn\src\SystemLayer\GdiPaintControl.cs:riga 130 in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) I only carry the first part because it is very long. if necessary, it will be complete. os : windows 10 home NET.framework: version 4.7.02046 I used microsoft tools to troubleshoot installer programs without finding the solution. thanks for any support Edited October 3, 2017 by erissimaco Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 3, 2017 Share Posted October 3, 2017 Do you have an Nvidia GPU? https://forums.getpaint.net/topic/111674-unhandled-exception-has-occured-in-a-component-in-your-application-if-you-click-cotinue-the-application-will-ignore-this-error-and-attempt-to-continue/?do=findComment&comment=534623 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
erissimaco Posted October 3, 2017 Author Share Posted October 3, 2017 (edited) 2 hours ago, toe_head2001 said: Do you have an Nvidia GPU? https://forums.getpaint.net/topic/111674-unhandled-exception-has-occured-in-a-component-in-your-application-if-you-click-cotinue-the-application-will-ignore-this-error-and-attempt-to-continue/?do=findComment&comment=534623 Hello,I got it, my laptop has an nvidia geforce gt 520 mx card. to which I recently updated the drivers. maybe the problem is this because in the past paint.net worked perfectly. perhaps the new drivers have created a conflict. in fact I'm also having problems with a game that contains files with extension tga. with this game if I use the poor graphics card integrated (intel 3000) it works fine. if I use the most powerful nvidia everything moves slowly and the interface has an incorrect graphics. I suspect that the 2 issues (paint.net and game) have a common cause of conflict with new nvidia drivers.Thanks for the attention. Edited October 3, 2017 by erissimaco Quote Link to comment Share on other sites More sharing options...
erissimaco Posted October 5, 2017 Author Share Posted October 5, 2017 Hello to all,I solved the problem with the help of a friend (Jan).I'll do it in case someone has the same problem:1st) I uninstalled the latest version of nvidia 385.69 drivers, with some difficulties because, every time I was asked to restart the system to complete the uninstallation, promptly reboot nvidia their drivers. until I restart for the third time I manually deleted all nvidia folders.2nd) I cleaned the OS and the registry and restarted ..3 °) After restart I started Windows Update I downloaded and installed the nvidia drivers version 376.54.4 °) I installed and started "paint.net" without any other problems.sorry for English is not my mother tongue.regards 1 Quote Link to comment Share on other sites More sharing options...
