Kies Posted August 30, 2016 Share Posted August 30, 2016 I'm trying to make a custom image for my Steam account by combining two images. I want to take the picture frame - style border from this image and combine it with the image of this image: (http://imgur.com/a/ROX9Z) Quote Link to comment Share on other sites More sharing options...
Pixey Posted August 30, 2016 Share Posted August 30, 2016 (edited) Hi there - you could: 1. Google for some golden frames and 'Save As' to desktop (or a folder). 2. Upload the image you want the frame to surround - which will be on its own layer. 3. Upload the frame - which will also be on its own layer. 4. With the magic wand click on the white area of the frame and hit delete to make it transparent. 5. With the Rectangle Select Tool encase the frame and move the 'nubs' to fit the size of your image. 6. Flatten and save. This may sound simplistic, but maybe more difficult than it sounds for someone doing this to start off. Good Luck . EDIT: Here is another example: This is AA's Assistant And here is how to install Plugins: Edited August 31, 2016 by Pixey Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
