Maikiria Posted June 27, 2008 Share Posted June 27, 2008 Okay, Ive looked around the site and asked for help at different places. But there are still somethings that I need help with. Layers are the big thing that I dont understand completely. I dont know how to have one layer show through to the next. Like for the picture below. I added another layer and did a purple gradiant on it, but it completely covers everything unless I unselect that layer. I really need someone to explain this to me. Im looking to edit pictures to do things like this: Quote Link to comment Share on other sites More sharing options...
pipp92 Posted June 27, 2008 Share Posted June 27, 2008 1. welcome to the forums 2. change your thread title to something that makes sense for example: help with layers 3. for your pic you can duplicate your layer, panel it, make a new layer on which you draw a gradient with secondary color alpha=0. tipp: try to follow most of the tutorials, if can't come forwards anymore, ask in the thread for it Quote Personal Gallery Link to comment Share on other sites More sharing options...
Myrddin Posted June 27, 2008 Share Posted June 27, 2008 Pressing F1 whilst in Paint.NET will direct you to the Help Files. Use them, they can be helpful. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Maikiria Posted June 27, 2008 Author Share Posted June 27, 2008 Thanks. =] I'll rename the thread since I understand a bit more now. Quote Link to comment Share on other sites More sharing options...
xRyan Posted June 29, 2008 Share Posted June 29, 2008 basically. you need to change the blend mode of a layer. you can do this by double-clicking one on the layers in the bottom-right corner on your screen and changing the blend mode. this should work. Quote [ My Gallery ] Link to comment Share on other sites More sharing options...
