cloud_strife Posted April 7, 2006 Share Posted April 7, 2006 Help i know this is prolly an easy process but please be nice to the noob!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
RejZoR Posted April 7, 2006 Share Posted April 7, 2006 Depending on the surrounding, you should do it fairly easy with Magic Wand. Just adjust proper sensitivity and select it. Use Ctrl and click on elements to select multiple parts. Then just move that to some other image. Quote Link to comment Share on other sites More sharing options...
Gladi8or2 Posted April 7, 2006 Share Posted April 7, 2006 You could also try SearedIce's method, described here as a step of a longer tutorial. It's used to cut the apple out of the picture. Quote Link to comment Share on other sites More sharing options...
SearedIce Posted April 7, 2006 Share Posted April 7, 2006 I described it differently here: http://paintdotnet.12.forumer.com/viewtopic.php?t=968 This should work fairly well. Once you have the head selected, copy it to the other photo by copy/paste Quote Link to comment Share on other sites More sharing options...
