duff muffin Posted January 24, 2008 Share Posted January 24, 2008 i need help! i made a picture, and then i closed paint after i saved it. i went to edit it, and i realized that i added a new layer so i can't change anything. can i change the things behind the layer? thanks Quote Link to comment Share on other sites More sharing options...
Curmudgeon Posted January 24, 2008 Share Posted January 24, 2008 not sure I understand what you mean. can you post a screenshot here of the picture with Paint.NET open on the desktop so we can analyze? Quote Link to comment Share on other sites More sharing options...
duff muffin Posted January 24, 2008 Author Share Posted January 24, 2008 may i ask how you do this? as you can see, i am a noob. Quote Link to comment Share on other sites More sharing options...
Panhead Posted January 24, 2008 Share Posted January 24, 2008 you add a layer to add more to the photo generally, you can click what layer you want to edit on the right hand side of the screen by, if you dont have the layers menu then reset window location under the window's menu at the top oh and to take a screen shot, look on your keyboard, top right hand corner, PrtSc, then paste somewhere Quote My deviantART iGraphix ~96% of teens won't stand up for God. Put this on your page if you're one of the 4% who will. skilletism (n.) - The abnormal liking of the band "Skillet". (see PANHEAD) panhead n. - an individual who shows extreme enthusiasm for the band Skillet. Generally driving for hours to concerts with frying pans riding shotgun. Link to comment Share on other sites More sharing options...
duff muffin Posted January 24, 2008 Author Share Posted January 24, 2008 i cant do the print screen, but i see the button. i did the reset, and it said that there was only one layer, but i know i used like 3. Quote Link to comment Share on other sites More sharing options...
Panhead Posted January 24, 2008 Share Posted January 24, 2008 did you save it as a .pdn? if not then it wont save the layers, it will flatten it (make one layer), it asks you though Quote My deviantART iGraphix ~96% of teens won't stand up for God. Put this on your page if you're one of the 4% who will. skilletism (n.) - The abnormal liking of the band "Skillet". (see PANHEAD) panhead n. - an individual who shows extreme enthusiasm for the band Skillet. Generally driving for hours to concerts with frying pans riding shotgun. Link to comment Share on other sites More sharing options...
duff muffin Posted January 24, 2008 Author Share Posted January 24, 2008 did you save it as a .pdn? if not then it wont save the layers, it will flatten it (make one layer), it asks you thoughyup, your right, thanks!problem solved! Quote Link to comment Share on other sites More sharing options...
