ZikeroX Posted November 4, 2007 Share Posted November 4, 2007 I am doing a banner, currently as we speak, for an rpg of mine. I need to add a few characters from animes. So, I found a render of one. I'm used to ImageReady, the animation program of Photoshop. Basically. On IR, it had Magic Eraser which got the background to match whatever was behind it. I see on paint.net there is no tool like it. But I can't outline the image for my life and I used magic wand to get most of the image out and I'm going around using the wand for small pieces. Is there a faster, and better, way of doing it? A plugin for a tool like the magic eraser, or some tool that can do it and I just haven't caught on. Please help me. Link to comment Share on other sites More sharing options...
Noodlez Posted November 5, 2007 Share Posted November 5, 2007 use this tutorial to cut out the anime character http://paintdotnet.forumer.com/viewtopic.php?f=15&t=4841&st=0&sk=t&sd=a&hilit=cutting+out+images and then inverse the selection (ctrl + i) and then delete and you should see a bunch of grey and white squares. the area with the squares with be transparent so it will show what ever you put behind it. hope that helps! My DeviantART | Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 5, 2007 Share Posted November 5, 2007 Please remember to use search: http://searchpaint.net . A simple search of "cut out images" would have answered your question. Thread Closed The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
