dirkdirka Posted September 23, 2007 Share Posted September 23, 2007 i want to make a sig but idk how to like bring the picture i want to put on it onto a new layer thing whenever i create a background and press open and select the picture it deletes everything and only has the picture as a background Quote Link to comment Share on other sites More sharing options...
Mr Frojo Posted September 23, 2007 Share Posted September 23, 2007 Layer/import from file Also, read rule number 6. This isnt descriptive enough Quote I'm still alive! Link to comment Share on other sites More sharing options...
dirkdirka Posted September 23, 2007 Author Share Posted September 23, 2007 thanks a lot and sorry ill try to be more descriptive nxt time Quote Link to comment Share on other sites More sharing options...
dirkdirka Posted September 23, 2007 Author Share Posted September 23, 2007 o but the picture i wana improt has a white background how do i fix that or do i have to cut the sword out of the white background so it is just the sword Quote Link to comment Share on other sites More sharing options...
Mr Frojo Posted September 23, 2007 Share Posted September 23, 2007 thanks a lotand sorry ill try to be more descriptive nxt time You can edit the title of this thread now Quote I'm still alive! Link to comment Share on other sites More sharing options...
Myrddin Posted September 24, 2007 Share Posted September 24, 2007 ...do i have to cut the sword out of the white background so it is just the sword Precisely. Search for a tutorial by the name of 'cutting out images the easy way' and that will describe in the easiest possible terms how to do such a task. You could also use an alpha mask which utilises the same method as the aforementioned tutorial but produces a cleaner and more professional extraction. Feel free to search for that too, it will be under the title of 'alpha masking'. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
dirkdirka Posted September 28, 2007 Author Share Posted September 28, 2007 thanks Quote Link to comment Share on other sites More sharing options...
