abbag Posted September 20, 2007 Share Posted September 20, 2007 i just can not seem to get the backrounds of my pictures white (get rid of the backround. i try using the magic wand and it get on the part of the picture i need. for example this is the one i have been trying to do for ages. Am i doing something wrong, cause honestly it is really confusing, please help me?? Quote Link to comment Share on other sites More sharing options...
abbag Posted September 20, 2007 Author Share Posted September 20, 2007 i have tried the tutorials but it was no hope, Quote Link to comment Share on other sites More sharing options...
Sunev Posted September 20, 2007 Share Posted September 20, 2007 This is the thread you will want to read. Cutting out images the easy way! Version 2. It's on the first page of the tutorial section. After you cut out the image, create a new layer colored white. Make sure your cut out image layer is on top, then merge your layers. Hope this helps. Quote Link to comment Share on other sites More sharing options...
MattBlackLamb Posted September 20, 2007 Share Posted September 20, 2007 If you want a transparent background. Do the tutorial, then save the image as a .PNG. Quote dA Son, someday you will make a girl happy for a short period of time. Then she'll leave you & be with men that are ten times better than you can imagine. These men are called musicians. Link to comment Share on other sites More sharing options...
