Derek Flint 0 Posted September 2, 2007 Report Share Posted September 2, 2007 Here is what I did: Opened PDN - OK Opened file (a jpg) - OK Image shows fine in PDN - OK Then Layers>Duplicate Layer - OK Duplicated layer selected and Effects>Blurs>Motion Blur - OK Set at Angle 11.00, Distance 200 Pixels, unchecked Centered - OK The image does not render either before or after pressing OK. I had waited several minutes before pressing OK. The image in the Layers box is correctly rendered but not the main image. Basically I followed Rick's Tutorial at rbrewster.members.winisp.net/t1/tutorial.htm. Hardware includes: AMD Athlon XP 3200+ @2.2gHz 1.5 GB RAM Sapphire/ATI Radeon X1650PRO AGP (256MBGDDR3) I could not find anything in this forum about this. Anyone have any ideas? Quote Link to post Share on other sites
Bob 4 Posted September 2, 2007 Report Share Posted September 2, 2007 Hope you understand. I think you accidentally unchecked the layer's visibility box. BTW, I'm loving the "Elegance" font. Seems like aatwo's one. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
Derek Flint 0 Posted September 2, 2007 Author Report Share Posted September 2, 2007 No - the layers visibility is checked. BTW - Windows XP here. The file was a large 1024x768 so now I have tried a much smaller image which is a 279x300 jpg at 7.65 KB. Still the same results. Quote Link to post Share on other sites
Bob 4 Posted September 2, 2007 Report Share Posted September 2, 2007 Does this fail on all pictures? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
I Like Pi 0 Posted September 2, 2007 Report Share Posted September 2, 2007 Is the motion blur applied on the top layer or bottom layer? If it's on the bottom layer, the top layer is hiding it. Quote Link to post Share on other sites
Derek Flint 0 Posted September 3, 2007 Author Report Share Posted September 3, 2007 I Like Pi - You are simply a genius! Yes that was it. The one layer was covering the other! I reduced the Opacity of the top layer and there was the image as it was supposed to be! Thank you so much! Quote Link to post Share on other sites
