xCensored Posted June 23, 2007 Share Posted June 23, 2007 I have a background I'm using for a sig. When I added in the water effect, it showed the "Water effectness", but along with that, it shows the transparacy. How do I change it or I can't? Quote Link to comment Share on other sites More sharing options...
Jud@s Posted June 23, 2007 Share Posted June 23, 2007 I've never tried to change it, tbh, donno if you can or not. But you can go around it by making a layer underneath with the same color as the water, or duplicate the layer you're making the water on, and do the water effect on the duplicate. Quote 100% PDN Link to comment Share on other sites More sharing options...
