MattBlackLamb Posted April 27, 2007 Share Posted April 27, 2007 I've been messing about with PDN for a week or 2 & this only just happened recently, it was after I downloaded some file extension plugins (.ico & .cur) I don't know if this is the problem. As the title says it works fine on the layer that I start with but if I try & do anything on another layer I have to move the points in very drastic places before anything happens. I have deleted the plugin files from my computer but this hasn't made any difference. Quote dA Son, someday you will make a girl happy for a short period of time. Then she'll leave you & be with men that are ten times better than you can imagine. These men are called musicians. Link to comment Share on other sites More sharing options...
MattBlackLamb Posted April 30, 2007 Author Share Posted April 30, 2007 Getting the latest update (3.07) didn't make a difference either. Quote dA Son, someday you will make a girl happy for a short period of time. Then she'll leave you & be with men that are ten times better than you can imagine. These men are called musicians. Link to comment Share on other sites More sharing options...
usedHONDA Posted April 30, 2007 Share Posted April 30, 2007 Well for now, you can download Curves+ in the plugin section. It does the same adjustment and more. Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
barkbark00 Posted April 30, 2007 Share Posted April 30, 2007 MattBlackLamb, I think I know what you are talking about. You are drawing on the top layer with anti-aliasing turned on and anything you draw has some slightly transparent pixels along the edge. If you try to blur a solid color it will only increase the amount of "slightly transparent" pixels. Those pixels are all the same(or relatively similar) color. Curves won't have much of an effect on those pixels in this situation. A black circle(top layer) over a white background(bottom layer) will always be black even though when you blur(otherwise alter) it, it looks like it is transitioning from black to white(via gray). The gray is just transparent black and adjusting curves will not effect a solid color. /blatant redundancy Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
MattBlackLamb Posted April 30, 2007 Author Share Posted April 30, 2007 Yeah, I think that's it thanks a lot Bark Bark Quote dA Son, someday you will make a girl happy for a short period of time. Then she'll leave you & be with men that are ten times better than you can imagine. These men are called musicians. Link to comment Share on other sites More sharing options...
barkbark00 Posted April 30, 2007 Share Posted April 30, 2007 No problem. Glad I could help... Quote Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
