eleonora Posted October 9, 2015 Share Posted October 9, 2015 Hi Rick, ok I did some more thinking after reading this post you quoted about manually re-creating the MSI. I did not need to go as far as re-creating it manually (as an aside, doesn't it madden you how Windows is taking control away from us - no such thing as Start -> Run in Win 10!). Anyway, I unistalled paint.net with Windows Apps and Features and then installed previous version 4.0.5. Made a copy of the MSI for that one for comparison, uninstalled, installed 4.0.6 and this seems to have done the trick. The install actually finished properly and when I looked the MSI for the earlier version had gone and the one for 4.0.6 is there. Re-started Windows and everything still there and working. Now, I recall distinctly that when everyting was going pear shaped there were wuite a few MSIs in the staging folder - about six or seven. That is probably one for every version I had before. I sincerely hope this is the last time I need to post on this topic. Look forward to posting more interesting stuff in future. Thanks for your help and patience. I know us users can be a pain sometimes. I used to be on the other end of it too, but my developing days are long over and technology seems to have got ahead of me, now I am retired! Quote Link to comment Share on other sites More sharing options...
ACMC Posted October 9, 2015 Share Posted October 9, 2015 I'm glad eleonora was able to get Paint.net to install, but by not being a developer, I'm not sure what she did or if I should even try it. Is there a description...in layman's terms...of how do to download Paint.net in Windows 10? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 9, 2015 Share Posted October 9, 2015 ACMC, you just download and install it normally. There are only a few instances of this type of stuff happening, as far as I can tell. (as an aside, doesn't it madden you how Windows is taking control away from us - no such thing as Start -> Run in Win 10!) It's there. Right click on the Start button, or use Windows Key + R. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
