Double Entries for Pixels
Hello,
I'm having problem with a plugin I'm writing (or at least part of the plugin).
What this code does is:
01. Looks for a pixel with a red value of 100
02. Writes to a log file the RGB | HSV | Pixel Coordinates
That's about it. It works great (thanks to paul_Nicholls for his post "Append to text file from inside CodeLab code"),
but the problem is that the log is getting double entries for pixels (averaging 2 entries per pixel).
I tested it by:
01. Using a pencil set to R:100.
02. Making one pixel dot onto to standard/default white.
03. Selecting an area.
04. Running the plugin.
Nine times out of ten the log file shows 2 entries for the one pixel. This is also true even when only the red pixel
is selected.
Just wondering if anything can be done to fix this problem. Perhaps paint.net uses overlapping ROI rectangles?
I've attached the source code only as you'll want to change the name and location of the log file if you'd like to test
it out on your machines.
Any help would be appreciated.
-Paul
// Name:
// Submenu:
// Author:
// Title:
// Desc:
// Keywords:
// URL:
// Help:
#region UICode
int Amount1=0;	//[0,100]Slider 1 Description
int Amount2=0;	//[0,100]Slider 2 Description
int Amount3=0;	//[0,100]Slider 3 Description
#endregion
void Render(Surface dst, Surface src, Rectangle rect)  {
 //START: RENDER CODE
     int TOP = rect.Top;
     int BOT = rect.Bottom;
     int LFT = rect.Left;
     int RIT = rect.Right;
     for (int V=TOP; V < BOT; V++)        { //START: VERTICAL: TOP TO BOTTOM LOOP (Y)
         for (int H=LFT; H < RIT; H++)    { //START: HORIZONTAL: LEFT TO RIGHT LOOP (X)
             ColorBgra CPIX = src[H,V];
             Color STDC = CPIX.ToColor();
             HsvColor CPHSV = HsvColor.FromColor(STDC);
             int CPR = CPIX.R;
             int CPG = CPIX.G;
             int CPB = CPIX.B;
             int CPH = CPHSV.Hue;
             int CPS = CPHSV.Saturation;
             int CPV = CPHSV.Value;
if (CPR == 100)                           {
 //START: CPR IF
                 System.IO.StreamWriter SW;
                 SW = System.IO.File.AppendText("C:\\Users\\CTCPublic\\Desktop\\geb\\CoolEdit.txt");
                 SW.WriteLine("R:" + CPR + "," + "G:" + CPG + "," + "B:" + CPB + " |" +
                              "H:" + CPH + "," + "S:" + CPS + "," + "V:" + CPV + " |" +
                              "coords=" + "V:" + V + "H:" + H);
                 SW.Close();
                                                       } //END: CPR IF
             dst[H,V] = CPIX;
                                                       } //END: LEFT TO RIGHT LOOP
                                                     } //END: TOP TO BOTTOM LOOP
                                                       } //END: RENDER CODE
write-tex03.txt
The Rise of the Creative Class
by: Richard Florida
Build this file to a DLL and install it in Paint.NET. It will not work in CodeLab, it must be built as a DLL in order to work.
// Name: Junk
// Force Single Threaded
#region UICode
#endregion
    dst.CopySurface(src,rect.Location,rect);
    string OutputFile = @"C:\Users\CTCPublic\Desktop\geb\CoolEdit.txt";
    StreamWriter SW=File.AppendText(OutputFile);
        if (IsCancelRequested)
            SW.Close();
            return;
            ColorBgra CurrentPixel = src[x,y];
            int R = CurrentPixel.R;
            int G = CurrentPixel.G;
            int B = CurrentPixel.B;
            int A = CurrentPixel.A;
            HsvColor hsv = HsvColor.FromColor(CurrentPixel.ToColor());
            int H = hsv.Hue;
            int S = hsv.Saturation;
            int V = hsv.Value;
            if (R == 100)
                SW.WriteLine("R:" + R + ",G:" + G + ",B:" + B +
                             " | H:" + H + ",S:" + S + ",V:" + V +
                             " | coords=V:" + y + ",H:" + x);
    SW.Close();
Remember to delete CoolEdit.txt before running the effect otherwise you might get duplicates as the second run will append to the existing file.
Click to play:
Thanks so much!
Is it okay to use CodeLab to build the dll?
From the looks of your code, I'm guessing that
...forces it to be single-threaded? Or is it closing the StreamWriter after all pixels are processed? Just wondering.
My C# knowledge isn't very great (and I just want to use it for paint.net plugins anyway), so stuff like "string OutputFile = @..." is awesome.
Thanks Again,
P.
by: Richard Florida
This code simply copies all pixels from the source canvas to the destination canvas. Remember, as a plugin author, you are responsible for writing to all of the pixels on the destination canvas. Since we won't be changing the pixels, I just did a quick copy.
This code forces the compiled DLL to be single threaded. Normally comments are ignored by a compiler and therefore have no effect on the compiled code. CodeLab is a little different. It uses the content of a few comments to change what is compiled for when code is compiled to a DLL.
"Single Threaded" means that the Render function will be called one at a time to process the selection instead of lots of threads calling Render all at the same time.
Because this is done in a single thread, you'll be sure that the output file is only ever opened by one thread at a time.
When an effect is in CodeLab itself, it is running multithreaded. Only the compiled DLL is forced to be single threaded.
Yes, you can use CodeLab to compile the effect. Just ignore the run errors while compiling it.
Click to play:
