How to grey out "Automatically check for updates when paint.net starts"
Hi all,
How could I grey out the options "automatically check for updates when paint.net starts" and "also check for pre-release (beta) versions of paint.net"?
The Reg Key values are 0 (meaning they are disabled); but I would like to grey out that option so a user would not be able to select it back.
Refer to attachment.
Any help would be appreciated.
Thanks
post-140992-0-04680100-1428519190_thumb.
You cannot disable this for a specific user. You can set the system-wide default, but a user may always re-enable it.
If you want to prevent a user from installing updates then you'll have to ensure they don't have Administrator-level privileges.
