aladin25 0 Posted February 13, 2014 Report Share Posted February 13, 2014 (edited) Hi, I have a problem when I try to place a text after I cut and paste an elliptic area. The problem occurs in the following Paint.NET versions: 3.5.10 3.5.11 4.0 Beta When I do the following steps I can not place a visible text: 1. I load a photo. 2. I select an elliptic area on the photo. 3. I create a new document 4. I insert the elliptic area in the new document. 5. I try to place a text The text is not visible. I check, the text is not transparent. I check the level direction. All of this all right, but I can not make the text visible. Have you a work around for me to solve the problem ? Best regards Aladin Edited February 14, 2014 by aladin25 Quote Link to post Share on other sites
pyrochild 362 Posted February 13, 2014 Report Share Posted February 13, 2014 When you have an active selection, most tools and effects can only change the pixels inside the selection. Press Ctrl+D or Esc to deselect, then the text tool will work anywhere. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
aladin25 0 Posted February 14, 2014 Author Report Share Posted February 14, 2014 Hi, thank you very very much. This solve my problem. Best regards Aladin Quote Link to post Share on other sites
