antoshaDjan Posted January 6, 2014 Share Posted January 6, 2014 (edited) Hello! This is really strange. My hotkeys in paint.net do work partially (ctrl + any button does whatever it's supposed to). I just can't select, for example, Pencil or Eraser tools. So, single button hotkeys do not work, and I have to choose the tools manually. Probably I missed some newbie preference, but the most weird part is that in, for example, GIMP any hotkey doesn't work, and in Photoshop everything works perfectly. If this helps, I'm on WIN7, 64 bit, and already reinstalled Paint.net couple of times. Thank you for your help in advance. Edited January 6, 2014 by antoshaDjan Quote Link to comment Share on other sites More sharing options...
skullbonz Posted January 6, 2014 Share Posted January 6, 2014 (edited) F lock on or off on the keyboard ? No,that wouldn't do it,none use those. maybe a bad keyboard Edited January 6, 2014 by skullbonz Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
antoshaDjan Posted January 7, 2014 Author Share Posted January 7, 2014 F lock on or off on the keyboard ? No,that wouldn't do it,none use those. maybe a bad keyboard I don't have any f-locks, it's a laptop, and otherwise then this graphic editors keybord works fairly well. That's really something weird going on... Quote Link to comment Share on other sites More sharing options...
