kacex Posted January 15, 2007 Share Posted January 15, 2007 I'm programming an interface where you can draw and add pictureboxes because I need to load some data in them, it is some kind of an aerial view of the buildings, and there are areas with machines that have some numbers and stadistics must be shown there... I added to my form a Picturebox called canvas where those controls can be added, which control do you use for drawing in your program? There's another problem about this, I can't save the "drawing" in images larger than the size of the screen, I've undocked the Canvas picturebox and gave it a higher resolution but I'm using a function that seems to take a Print screen of the area, and everything else is in black... I was hoping you could help me do this with your experience in your program... Thank U Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 15, 2007 Share Posted January 15, 2007 Sorry, this forum is for questions regarding Paint.NET, not general help with WinForms programming. Locked The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
