WarmNachos Posted January 27, 2013 Share Posted January 27, 2013 Hello, I've recently been trying to make a picture and I need Anti-Aliasing disabled for it. Now I have it disabled, but whenever I try to do effects like Dent it adds some Anti-Aliasing in it even thought Anti-Aliasing is disabled.. When I do use Dents I even try setting quality to 0 but that doesn't seem to do much. Now I may be missing something here and which is most likely true but I can't seem to find out how to permanently disable Anti-Aliasing for everything. It's disabled right now but whenever I try to use Effects it uses Anti-Aliasing which I don't want it to. Any way to have Effects not us Anti-Aliasing or to completely disabled it? Thank you for your help! Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted January 28, 2013 Share Posted January 28, 2013 Anti alias is not a global setting. Whether or not a plugin has the option of turning it off depends on if the plugin author included such an option. In other words, no. Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
WarmNachos Posted February 6, 2013 Author Share Posted February 6, 2013 Sorry it took me so long to reply. Well, I found out I will just have to use the magic wand tool and use fill to get rid of it myself. Not too hard at all. Anyways thank you for your reply. Quote Link to comment Share on other sites More sharing options...
