peanut0070 Posted June 20, 2012 Share Posted June 20, 2012 Hello, im trying to get rid of a specific color and replace it with black, the color is all over the picture in different parts. I recently came across this program and it almost worked. It got rid of the color but replaced it with white. How do i get it to replace it with black. Is there another program? Quote Link to comment Share on other sites More sharing options...
yellowman Posted June 20, 2012 Share Posted June 20, 2012 (edited) Try this, add a new layer and fill it with black using Paint Bucket , then move this layer down, Flatten and Save As. Make sure to save as new name, so you keep the arginal file. Edit: sorry I meant original file. Also you can duplicate the top layer as much as you like for a better result if it needs. Edited June 20, 2012 by yellowman Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
peanut0070 Posted June 20, 2012 Author Share Posted June 20, 2012 Woooo! Success! Thanks so much for your help!! Quote Link to comment Share on other sites More sharing options...
