Gretzlaf Posted June 3, 2011 Share Posted June 3, 2011 I've recently been having some trouble using the magic wand tool to make images transparent. Before a few weeks ago, I wasn't having any trouble with it. But for some reason, nowadays when I try to save an image that I've cut the background from, it saves with a white background instead. I'm not sure what the problem could be, I updated and everything but it still won't let me save transparent images. Anyone know how to fix this? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
mountnman Posted June 3, 2011 Share Posted June 3, 2011 sounds as if the file type you are saving as doesnt support transparency.. save as a .png and you should have no problem Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
Gretzlaf Posted June 3, 2011 Author Share Posted June 3, 2011 Yup, that was it. Thanks. Quote Link to comment Share on other sites More sharing options...
